Hi guys.
I need some advice please.
My polo is throwing fault codes at the moment, basically the following:
17950 - Angle Sensor 1 for Throttle Actuator (G187): Implausible Signal
P1542 - 35-10 - - - Intermittent
17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
P1544 - 35-10 - - - Intermittent
17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
P1172 - 35-10 - - - Intermittent
Readiness: 0000 0000
I've cleaned the throttle body, and cleared the codes, but I'm still getting these faults.
Is there anything else that I can do? GW want R7500 for a new throttle body. Ouch.
Thanks!
Polo throttle body fault codes
- Car Model: 2004 Polo 1.6 Trendline
VW polo 1.6i 2004 - Just as VW made it
Re: Polo throttle body fault codes
Im having the same issue how did you slove your problem
Replace it..
