Signs of a failing Fuel Pressure Regulator?
- M3THANOL
- Blue Bomber
- Car Model: Golf Mk2...now....2.0L 8V AGG
- Membership No: 1822
Morning all
I am beginning to think that the FPR (Fuel Pressure Regulator) on my 2.0 8v AGG is not working as it should. The symptoms include:
1) On cold start in the mornings the engine cranks, starts and then dies after about two seconds, then usually starts and runs on the second try, but sometimes it dies again and then runs fine on the 3rd try
2) Once the engine is hot, if I switch it off and then come back say half an hour to an hour later ( if I go to the shops, or park at home and then need to go out again) the engine will start and idle for a few seconds and if I don't blip the throttle a few times it will die but once I have given it a few blips it idles fine, with the occasional "drop" or hunt in the revs for a short while until I start driving.
3) I have noticed that when I turn the ignition on and allow the pump to prime for a while without starting, I can hear an unusual bubbling type sound coming from the fuel rail, not something that can be heard when the engine is running but only when the pump is priming.
I haven't yet tested to see if petrol comes out of the vacuum port on the FPR, I will give it a try today but I thought it would be best to get a thread going where some possibilities can be listed.
I'm literally can't evening!
http://www.iamsecond.com/
Current: The Blue Bomber
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=151592
1/4 mile: 16.5s @ 133km/h (ODI-2013/10/27)
1km: 165km/h (ODI-2013/10/27)
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
Re: Signs of a failing Fuel Pressure Regulator?
Not 100% convinced it's the FPR, you should be noticing a drop in power/running lean if it starts failing. Your water temp sensor may be on it's way out or in need of calibration.M3THANOL wrote:Morning all
As far as I know that's the sound of the fuel returning to the tank and indicates that the FPR is achieving its 'requested' pressure and allowing fuel past. If it's failing however it will allow fuel past after reaching a pressure lower than 3Bar, which is what causes the problem. It however is not a sign of a failing FPR.
I don't believe that fuel will ever come out of the vacuum port/tube. If i'm not mistaken that is just to allow the FPR to adjust according to the difference between manifold and atmospheric pressure.
- Car Model: 18 Polo Vivo
- Membership No: 1691
Put a fuel pressure guage on it and see what its doing.
I had a feeling mine was giving crap from the loads of fuel the car was using.
When fuel pressure is low, would also not rev up cleanly and sometimes jerk high up in rev range.
Starting then dying sounds like cold start or temp sensor on its way out.
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
- M3THANOL
- Blue Bomber
thanks for the input bud, will keep it in kind. One will find fuel coming through the vacuum port if the diaphragm has a tear in it.CCBB wrote:Not 100% convinced it's the FPR, you should be noticing a drop in power/running lean if it starts failing. Your water temp sensor may be on it's way out or in need of calibration.M3THANOL wrote:Morning all
- M3THANOL
- Blue Bomber
I don't have a fuel pressure gauge yet, I guess I should look into getting one.nd_s wrote:Put a fuel pressure guage on it and see what its doing.
I will hook up my laptop today to the XMS and see if anything is out of the ordinary.
- RIAZ
- Car Model: CitiRox 1.4i 2008 Model
- Membership No: 3092
Good day
My VW CitiRox starts and dies after two seconds sometimes very rarely but it irritates the hell out of me , even after i changed the temp sensor put one in from vw it still does it but very very rarely any help
Thank you
Thank you
- Goldwagen Delarey
- Car Model: GOLF 1 1870cc 8v ethanol
- Membership No: 1800
Fuel rail are more common to go. They crack on the inside and then start bypassing the regular. Try to clamp the return ans if there is a noticeable difference.
- RIAZ
how would one repair this if it is the fuel rail , cost of spares ? labour
- Goldwagen Delarey
Put a external regulator on..Riaz Amod wrote:how would one repair this if it is the fuel rail , cost of spares ? labour
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
- M3THANOL
- Blue Bomber
shot Viper , will give it a tryViper wrote:Fuel rail are more common to go. They crack on the inside and then start bypassing the regular. Try to clamp the return ans if there is a noticeable difference.
Hey i have a golf gti mrk 7 and have the exact same issue, ive had the same issue for the last 8 months and please could you tell me how you resolved it. I have changed many things such as the breather, camb belt sensor and nothing has resolved it.
Golf 7 has a vastly different setup to the car above. Not anything in this thread will even remotely assist you in solving a fuel issue on a golf7.
Start a new thread of your own describing your issues.
- BIGMIG
- Porra Love
- Membership No: 1574
Can also try the search function. Might be a bit tricky but could help you out.
- Registered for: 5 months
hi all i also have an golf cabrio with agg motor where does one plug in the pressure tester, as i cnt see a place on the fuel rail
thanks in advance
thanks in advance
