Intermittent White Smoke on MK6 GTi??!!
- Smok3X
- Car Make: SEAT
- Car Model: LEON CUPRA 2.0 TFSi K04
- Membership No: 3083
Hi Guys,
I need some advice.
My brother purchased a Golf 6 GTi 3 weeks ago and has had endless issues from day one!
The problem now is that it has this intermittent white smoke problem. I dont know how else to describe it. I have driven behind him several times, at full throttle there is no smoke, idle no smoke, overrun no smoke, cold start no smoke.
Then just randomly,there will be white smoke on overrun and then on idle at a robot for a few seconds. So much so, that you can actually smell the smoke inside the car.
The car has been to VW 5 times now! And they cannot find the issue. It had an intake, DP and software but now all tat has been removed.
VW have checked everything, compression test was fine and so was the PCV Valve...
What else could be causing this issue?
Its a 2011 6 GTi with 41 000kms on it.
I need some advice.
Leon CUPRA - 2.0TFSi K04--> Rides Thread
169WKW@Dark Artz - Stock
229WKW@Dark Artz - RevO 2+
Ibiza CUPRA - 1.8 20V - Hybrid Turbo-->Rides Thread
Revo:182KW and 399NM@Experience
ABF Citi Golf - 2.0L 16V--->Rides Thread
FRC - 124KW and 198NM@Auto Trix
1/4 Mile:14.61s
1ST Place - 4AF2 Margate 31st Oct 2010
1/4 Mile:14.61s
- Membership No: 1708
Re: Intermittent White Smoke on MK6 GTi??!!
Turbo seal?
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
Could be a turbo seal that's letting some oil into the intake on occasion. Have you checked the PCV system for leaks and/or blockages?
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Solo786
- Car Make: Porsche,BMW,VW
- Membership No: 1251
Change the tappet cover and report back..
- Scatman
- General
- Car Make: BMW
Surely you mean tappet cover gasket?Solo786 wrote:Change the tappet cover and report back..
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Solo786
No, i mean the entire tappet cover..
- PoLonY
- Car Model: A8
- Membership No: 1997
care to explain why?Solo786 wrote:No, i mean the entire tappet cover..
- Smok3X
- Car Make: SEAT
The car has been to VW McCarthy in Durban, 5 times as of today.
They claim that there is nothing wrong with the car. All the usual suspects, such as Turbo seals have been checked.
1/4 Mile:14.61s
1/4 Mile:14.61s
- Smok3X
- Car Make: SEAT
I agree, please shed some light?PoLonY wrote:care to explain why?Solo786 wrote:No, i mean the entire tappet cover..
Because my brother is ready to cancel the deal now. This is BS
1/4 Mile:14.61s
1/4 Mile:14.61s
- Solo786
rear pcv which is built into the tappet cover has a check valve in it, this check valve fails sometimes and when enough oil builds up it pushes oil into the turbo.
a quick test - with car idling open the oil cap and lift it slightly, if you can feel a vaccum sucking it back down, then its likely that theres a pcv problem - front or rear is for you to find out.
A mk5 with this problem was fixed with a new tappet cover as the rear pcv was shot. Depending on how accurate vw's diagnosis of your front pcv was, will decide if its also your rear pcv thats gone
- PoLonY
- Car Model: A8
Ah i see, thanks for that infoSolo786 wrote:rear pcv which is built into the tappet cover has a check valve in it, this check valve fails sometimes and when enough oil builds up it pushes oil into the turbo.
I found the problemSmok3X wrote:The car has been to VW McCarthy in Durban, 5 times as of today.
- Scatman
- General
- Car Make: BMW
That explanation makes sense - good info Solo
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Ian F's special snugglebunny
- Car Model: Caddy
- Membership No: 1548
Wealth of knowledge Solo has.
Thanks Solo, will keep this in mind for future.
- Smok3X
- Car Make: SEAT
Sadly... all this drama has just been a bit too much and my brother will be cancelling the deal tomorrow.
To spend almost 300k on a car and have it go to VW 5 times in 3 weeks is just ridiculous.
1/4 Mile:14.61s
1/4 Mile:14.61s
- Titleists
- Philosopher STIG
- Car Model: 2016 Golf R
- Membership No: 1520
Spending R300k on a 2011 model is just ridiculous. Tell him to search some more, Retail value on a 2011 DSG is probably around R240k now.Smok3X wrote:Sadly... all this drama has just been a bit too much and my brother will be cancelling the deal tomorrow.
- ryanrich
- Car Make: Ford
- Car Model: Territory
I would've taken it back too, you don't wanna deal with that just after buying a car. I had an issue with my A3 Sportback a few years ago. It needed a cylinder head replacement straight after buying it. Luckily for Audi Freeway Plan...
Depends on condition, extras, mods etc. I sold my 2011 Manual for R280k two weeks ago.Titleists wrote:Spending R300k on a 2011 model is just ridiculous. Tell him to search some more, Retail value on a 2011 DSG is probably around R240k now.Smok3X wrote:Sadly... all this drama has just been a bit too much and my brother will be cancelling the deal tomorrow.
2016 Ford Territory TDCi Titanium AWD
2016 Kia Sportage Si
- Titleists
- Philosopher STIG
You lucky bastard . I got R235k and my car was spotless, granted I was in a hurry and the fact that the engine was replaced didn't help . I shall never pay more than what the book says though.ryanrich wrote:I would've taken it back too, you don't wanna deal with that just after buying a car. I had an issue with my A3 Sportback a few years ago. It needed a cylinder head replacement straight after buying it. Luckily for Audi Freeway Plan...
- Smok3X
- Car Make: SEAT
We are indian bud, we never pay more! I said "almost"Titleists wrote:Spending R300k on a 2011 model is just ridiculous. Tell him to search some more, Retail value on a 2011 DSG is probably around R240k now.Smok3X wrote:Sadly... all this drama has just been a bit too much and my brother will be cancelling the deal tomorrow.
It was R260k for a 2011 Manual with 41k on the clock. Plus the OE 6R LED Tail lights.
Anyway... He is looking for another one... anyone have a 6 GTi for sale with similar specs and price?
1/4 Mile:14.61s
1/4 Mile:14.61s
- Car Model: Caddy
Plenty around bud,Smok3X wrote:We are indian bud, we never pay more! I said "almost"Titleists wrote:Spending R300k on a 2011 model is just ridiculous. Tell him to search some more, Retail value on a 2011 DSG is probably around R240k now.Smok3X wrote:Sadly... all this drama has just been a bit too much and my brother will be cancelling the deal tomorrow.
Just keep a look out. Good luck with finding one.
VW MK7 GTI DSG. White.
MB C200 Avantgarde A. Palladium Silver.
Ex's
2006Mk5 Jetta 2.0 TFSI DSG. Silver
2002Mk4 Gti. Silver
2008 MB C180k Avantgarde A. Silver
2011 6R Polo Gti. Silver.
2005 9N TDI Sportline. White
2001 MK4 GTI. Black. Sunroof.
1996 MK3 GTI. White. S3 wheels.
2000 MK4 2.0 Highline.GTI Wheels.
1991 MK2 GTI. White. (Best car owned ever)
1991 MK1 CTI. White. Momo EVO1's
Ex's
2002Mk4 Gti. Silver
So what was the issue
I’m having the same problem with mine I changed turbo have after it’s tuned apr (3” stainless turbo back cat less exhaust forged pub plate with catch can also has apr carbino cold air intake and red top coil packs like I said I swapped out turbo and still get clouds of white smoke from burning oil at random times then other times it will smoke on cold start and I rpm driving I’m lost on what else to do please help
- grease monkey
- Car Make: Golf
- Car Model: MK2
Solo takes the prize here , but a similiar issue I had was residual oil in the intercooler that seemed to release a bit into the system at random times
