Hazard - bordnetz
- Car Model: Golf IV GTi (132KW)
- Membership No: 1158
Hazard - bordnetz
Hi All,
I have the problem on a 2008 Citi 1.4i where Hazards seem to go on randomly. I even disconnected the Hazard switch for a week and still went on randomly.
I also changed the Hazard switch.. But Hazards still go on randomly.
Been told it could be the bordnetz...
I cannot find a 2nd hand one with my part number.
Any other Ideas or options before I get new one..
Weird thing is that VCDS does not pick up any faults with the bordnetz..
Address 09: Cent. Elect. Labels: None
Part No: 17S 937 049 E
Component: BORDNETZ-SG. V2.03
Coding: 00000
Shop #: WSC 00000
VCID: 408B44336A13
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Coding: 00000
Shop #: WSC 00000
VCID: 408B44336A13
No Faults Found
Kuven Aramugam
E-Mail: kuven0107@gmail.com
Contact #: 083 716 4455
2005 VW Polo 1.9 TDi Sportline
2010 VW Golf MK6 GTi DSG
Previous Rides:
1984 MK1 GT (Sold)
2003 Golf 4 1.6i 2door (Sold)
1967 VW Split Window Panel Van(Sold)
1962 VW Split Window Crew Cab (Sold)
2003 Golf 4 GTI(sold)
Previous Rides:
1984 MK1 GT (Sold)
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Re: Hazard - bordnetz
You indicators work fine though?
If you can, swap boardnetz with another citi & gauge.
Sounds like a earth/wiring issue to me...
Indicators working without any issues. The car did have some weird cutoff switch but that was disconnected.
If I use another bordnetz to test, will indicator, hazardss still work and jus car won't start due to bix not being coded?
Naku786 wrote:You indicators work fine though?
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
How did the cut of switch work, from where did they take power? did they cut into the loom to bridge the fuel pump power?MK1-GT wrote:Indicators working without any issues. The car did have some weird cutoff switch but that was disconnected.
Hmmm im not 100% sure, but I think it will work. ( i have a decoded ecu so had issues swapping)
Imm not sure how the cutoff was connected but a very reliable persson disconnected it. Any ideas where I can check for a wiring diagram maybe?Naku786 wrote:
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
Ok thanx dude., I will try and see if I can figure it out or will just try an electrician if I dont come right.
But I had the battery disconnected (positive was off the terminal). I connected it last night to try and start the car and immediately when I connected the Terminal the Hazards came on... So something is a bit strange...
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
Sounds like a short in your wiring to the hazard switch...
Trust me when I say its the boardnetz unit its an old problem see " http://vwclub.co.za/forum/viewtopic.php ... 4#p1928661 "
Also your boardnetz will not show that fault!
Andrew
Andrew
It a very weird and confusing problem.. Thanks for all ur assistance dude. ..Naku786 wrote:Sounds like a short in your wiring to the hazard switch...
Thanks, was just trying to see and rule out all other possibilities first...But seems like going to have to get a new bordnetz...cpureaper wrote:Trust me when I say its the boardnetz unit its an old problem see " http://vwclub.co.za/forum/viewtopic.php ... 4#p1928661 "
Andrew
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
When its flashing disconnect the boardnetz unit should stop had similar problems with rear wipers
Andy
Andy
Ok so last night I decided to take out the bordnetz and check it out..
While I was taking it out and trying to unplug the 2 cables, the hazards when on....
Seem like this bordnetz was worked on before.. Opened the bordnetz up and seen tracks might be damaged.
Check the bottom right of the board.
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
Ahh the good old water problem! If you can get someone to re solder the tracks and the pin contacts. Well done with your find! What is the number on that bordnetz? Andy
I even forgot water could have also caused it...cpureaper wrote:Ahh the good old water problem! If you can get someone to re solder the tracks and the pin contacts. Well done with your find! What is the number on that bordnetz? Andy
Part number is 17S 937 049 E
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
That sure looks like water! check both the x relieve relay and the fuel pump relay as they are upside down. even if not try and turn the relays around. Did u get it resoldered? Also how do the terminals look on the connectrs?
Where about do i find those relays? are they also same place under the dash?cpureaper wrote:That sure looks like water! check both the x relieve relay and the fuel pump relay as they are upside down. even if not try and turn the relays around. Did u get it resoldered? Also how do the terminals look on the connectrs?
I bought a new bordnetz on saturday and plugged it in at about 4pm... From 4PM saturday till last night, sunday @ about 8 the hazards never went off automatically... So it seems that it was the bordnetz. I disconnected the battery so that the battery doesnt die cause i currently not using the golf.
I am also going to check who can solder that box for me and keep maybe as a spare...
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
Same side right hand close to the fuse box 53 on the two!
Andrew
Andrew
hi guys
please assist,my box for the indicators is damaged and i would like to get another one,can you please hook me up.
Hi there..
U will need to check at scrapyard.. I found one from a guy that was stripping citi golf.
Sorry bud.
Sorry bud.
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
