Cigarette Lighter Socket Removal
Anyone know how to remove the cigarette lighter socket from a polo 6r? Any help appreciated
- Car Model: Polo Playa
Re: Cigarette Lighter Socket Removal
In most cars, it just "fits" into the console. You should be able to pull it out with the help of a flat screw driver. But some have a screw or two at the back end and you'll need to remove some of the dashboard or other panels close, under or above it.
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
I would suggest unplugging it first or removing the fuse before sticking a screw driver in there.
It should be off by default, if the ignition is off. But, yeah, make sure there's no power to the socket before you remove it.Naku786 wrote:I would suggest unplugging it first or removing the fuse before sticking a screw driver in there.
- Car Model: Polo 6r 1.4 Comfortline
- Senna
- Car Make: VW,BMW
- Car Model: MK5 GTi/CrossCaddy/325iS
- Membership No: 3101
