Talking about fuel lines, that is another area where you can clean up, fit a Polo fuel filter with integral 3 bar regulator by the tank and you just need one fuel line to the front directly onto the fuel rail.vdub caddy wrote:Curiosity has got the better of me, why do the fuel lines come in on the right hand side of the motor?
Normal Citi's/MK1's have the steel lines coming in from the left hand side of the motor.
This is standing with the bonnet open infront of the motor obviously.
shaved engine bay - mk1
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Re: shaved engine bay - mk1
Current rides:
Hyundai - 1.4 Getz (daily)
- Voora Molester
no return needed?Torker wrote:Talking about fuel lines, that is another area where you can clean up, fit a Polo fuel filter with integral 3 bar regulator by the tank and you just need one fuel line to the front directly onto the fuel rail.vdub caddy wrote:Curiosity has got the better of me, why do the fuel lines come in on the right hand side of the motor?
Thupercharged S4
- General
Depends where you mount it, mine is right next to the tank so the return hose is only about six inches long. There is no vacuum point on this setup so your management must be able to compensate the fuelling instead, I'm using Dicktator std.yakuza racer wrote:no return needed?Torker wrote:Talking about fuel lines, that is another area where you can clean up, fit a Polo fuel filter with integral 3 bar regulator by the tank and you just need one fuel line to the front directly onto the fuel rail.vdub caddy wrote:Curiosity has got the better of me, why do the fuel lines come in on the right hand side of the motor?
Current rides:
- Voora Molester
will see what i can do, those ingle fuel rails look the part as well
Thupercharged S4
- Criminal Troll.
I have done it on a honda before.
Becareful and label all wires before lengthening harnesses, use as little body filler as possible and make sure you use double flares on brake lines.
I ran the wires in the fenders, brakelines inside the cabin, relocated the battery, used braided fuel lines with AN fittings and an earls fuel filter.
All brake lines were done with AN fittings, teflon braided hose and the hard lines were remade and flared.
