Then you screwed, drill the hubs?graham savage wrote:Offset prevents adapters - that's the bit I'm concerned about
PCD change
- span die seile
- Membership No: 1746
Re: PCD change
- BB-GP
- Car Make: vDubz
- Car Model: 2.0TDi Caddy Alltrack
Re: PCD change
@kibim
The centre bore of the hub is 57.1mm (std) and so is the S3 rim.
the adapters will be made up according to those sizes.
If i understand correctly, spigots wont be needed?
- SHAUN
- Post Whore
- Registered for: 19 years 9 months
- Car Make: BMW
- Car Model: 2006 335i
- Membership No: 1148
Re: PCD change
Correct.BB-GP wrote:@kibim
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
- graham savage
- Colonel
- Membership No: 803
Re: PCD change
Zigacktly but last time i called gulf auto the guy says naught, we don'lookt do it... you won't catch me near the wheel shop and after that I'm out of options... hey maybe Malta can help, all the bits are off the car nowkatotter wrote:Then you screwed, drill the hubs?graham savage wrote:Offset prevents adapters - that's the bit I'm concerned about
- PoLonY
- Car Model: A8
- Membership No: 1997
Re: PCD change
Hey Guys
Very old thread revival.
I want to fit a Jetta VR6 5 stud rim to a MK1 golf which is 4 stud.
Can you advise if adapters or drilling the hubs are the way to go?
Any recommendations on where I can source some adapters in the Gauteng area?
- Car Make: Ford
- Car Model: Focus ST
Re: PCD change
Thanks, will contact them.
Any idea what thickness adapters I need to ensure no touching of the tire and fender?
- Neuk
- Treasurer
- Membership No: 806
Re: PCD change
MkI PCD is 4x100 and MKIII VR6 PCD is 5x100 so you can redrill the hubs without too much issue, I had this done on my ex Caddy to run MkIII Golf VR6 wheels.MK_1 wrote: ↑Sun May 09, 2021 11:21 pm Hey Guys
Re: PCD change
Thanks for the advise guys.
Got a quote of R2950 for the adapters.
Will try and find a place for drilling, if the price is anywhere close to the adapters I might as well just go the adapter route.
- Car Make: Ford
Re: PCD change
You'll probably pay a third for drilling...
A year or two ago those adaptors went for under R2k IIRC.
2010 ST225 - 238kw 439nm
- Car Make: mk1
- Car Model: GTX
Re: PCD change
If you are close to Florida on the West Rand you can try
GULF Auto spares in Goldman str.
They do [did do] drilling of the hubs
