272 vs 276
Classic8
Car Model: Polo classic
272 vs 276
Post by Classic8 » Thu Nov 29, 2012 12:13 am
hi im going for a cam in my 2l 8valve which one would be best preferred as i use my car daily?
I know this is always a debated topic and if i go for 272 can i keep my own vernier or should i get a other venier?
Vinnige Fanie
Lazy Poes
Car Model: 8P3 S3
Membership No: 1720
Re: 272 vs 276
Post by Vinnige Fanie » Thu Nov 29, 2012 7:49 am
Classic8 wrote:hi im going for a cam in my 2l 8valve which one would be best preferred as i use my car daily?
Hi Bud do you have a Piggyback or Unichip of some sort?
My first great love:
1999 Vw Polo ABF 16v with some Dubtec.
138.5HP & 147NM
http://www.vwclub.co.za/phpbb3/viewtopic.php?t=61419
The New mistress:
http://www.vwclub.co.za/forum/viewtopic ... 1&t=195525
Pulse Stage 2
phillip
Car Model: 225 ST
Re: 272 vs 276
Post by phillip » Thu Nov 29, 2012 8:29 am
You can use a 298 cam in your daily, been asked plenty on the forum.
Its all how much you want and can handle, for some guys 276 is too much but others a 288 is still not enough.
I ran a 288 in my 2l 8v and i loved it, if i could go back i would put a 298.
Like fanie asked, do you have a piggy back system, management? if not fueling might be a problem.
But if it was my choice 276 minimum.. 272 is for a 1400 :lol:
Focus ST
EX
City.Com ABF
Dono82
Car Model: Focus ST250
Re: 272 vs 276
Post by Dono82 » Thu Nov 29, 2012 8:31 am
hey bud...
just had my 276 removed from my 2.0l 8v....
it was very nice and smooth, with a slight of beat idol..
but change back to a G-cam...its perfect for everyday use. got loads of torque from right at the bottom and is very very smooth.
only other mods is a gotech Mini-X, and a 57mm exhaust not even a branch. made 83wkw yesterday... :grin:
198.9wkw and 526nm @ KAR
Re: 272 vs 276
Post by lawrence » Thu Nov 29, 2012 10:40 am
Dono82 wrote:hey bud...
and I went the other way..... bwahahahaahaaaa.... from a 276 to a 288 and am already considering a 298 :oops: :grin:
TBH I would not run anything less than a 276
ACiD_Omega
Car Model: 2004 Chico under construction
Membership No: 1820
Re: 272 vs 276
Post by ACiD_Omega » Thu Nov 29, 2012 11:20 am
OP does not state capacity
Re: 272 vs 276
Post by lawrence » Thu Nov 29, 2012 11:23 am
ACiD_Omega wrote:OP does not state capacity
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Re: 272 vs 276
Post by VWicked » Thu Nov 29, 2012 11:27 am
Acid, it says 2.0 8v
For daily i would go 276 as its a mix between power and fuel consumption. I had a 288 in my car but it drank loads more fuel. Bottom end is also severly affected but that didn't bother me as I do not short shift my car.
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
ACiD_Omega
Membership No: 1820
Re: 272 vs 276
Post by ACiD_Omega » Thu Nov 29, 2012 11:39 am
ooops, sorry, I missed that completely
Torker
Car Model: Golf GT
Membership No: 1464
Re: 272 vs 276
Post by Torker » Thu Nov 29, 2012 11:44 am
Depends what you can live with - I've seen guys pull 276's out of 2.0 engines because they could not handle the lumpiness, I consider a 276 just about stock and grew bored with it in a couple of months...
Current rides:
Hyundai - 1.4 Getz (daily)
VWicked
Membership No: 1492
Re: 272 vs 276
Post by VWicked » Thu Nov 29, 2012 12:48 pm
Torker wrote:Depends what you can live with - I've seen guys pull 276's out of 2.0 engines because they could not handle the lumpiness, I consider a 276 just about stock and grew bored with it in a couple of months...
agree, 276 should be the stock cam on 2.0. on my cti, it was smooth with the 276, no lumpyness
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
Classic8
Re: 272 vs 276
Post by Classic8 » Fri Nov 30, 2012 2:30 am
Ok so i guess its then going to be the 276 cam. It sounds great and i can see the excitement with the 276. is it nessesary for head work with the 276 or can i run it as is and will i need a other vernier pulley or must i use standard vernier pulley?
Re: 272 vs 276
Post by panic-mechanic » Fri Nov 30, 2012 7:22 am
I'm unsure that you know exactly what a vernier pulley is but yes you can use the standard timing pulley that the car comes with.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
Psycho8v
Car Model: Citi Golf
Membership No: 1881
Re: 272 vs 276
Post by Psycho8v » Fri Nov 30, 2012 8:39 am
Sorry for the hijack. But I think this can be relevant information to the OP as well.
Alot of people say that the 276 is a nice smooth cam for a 2.0 8v, what about the 282 cam? How does that compare to the 276 as an everyday cam. Is there a big difference in fuel consumption? (i know it's got alot to do with controlling your right foot) How is the power delivery? Any info will be great. :hi:
Torker
Car Model: Golf GT
Membership No: 1464
Re: 272 vs 276
Post by Torker » Fri Nov 30, 2012 8:47 am
I don't think the choice of cam plays that big a factor in consumption, all the variants I had - 276 in 2.0, 288 in 2.0, 298 in 2.0, 298 in 2.1(hydro) and now 300 in 2.1(solid) had basically the same consumption, around 10l/100km, my driving style is pretty consistant but if you are hooning it all the time the consumption will cetainly suffer.
Current rides:
Crawler
Car Model: 9N3 Polo TDi
Membership No: 1358
Re: 272 vs 276
Post by Crawler » Fri Nov 30, 2012 8:50 am
Wow torker you been through the range
CW Polo TDi Sportline
Torker
Car Model: Golf GT
Membership No: 1464
Re: 272 vs 276
Post by Torker » Fri Nov 30, 2012 8:53 am
crawler wrote:Wow torker you been through the range
LOL, I think I finally hit the sweet spot in terms of performance with the last one, but that said, I've still got a 316 solid lifter cam in my cupboard...
Current rides:
Zubair
Car Model: MK1
Re: 272 vs 276
Post by Zubair » Fri Nov 30, 2012 9:08 am
I've had all sorts of combos on 8V's and 16V's. 276 is the bare minimum on a 2.0, in fact its nice on an 1800 and 288 on a 2.0 is better as its got more low end torque. I've driven 8v and 16v with 288's in traffic, no issues, also didn't notice any consumption differences from 276. If you can't handle a 288 in traffic, you a learner driver.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
Psycho8v
Membership No: 1881
Re: 272 vs 276
Post by Psycho8v » Fri Nov 30, 2012 9:14 am
Torker wrote:I don't think the choice of cam plays that big a factor in consumption, all the variants I had - 276 in 2.0, 288 in 2.0, 298 in 2.0, 298 in 2.1(hydro) and now 300 in 2.1(solid) had basically the same consumption, around 10l/100km, my driving style is pretty consistant but if you are hooning it all the time the consumption will cetainly suffer.
Thanks alot Christo. This is actually good to know, as my arse is itching for the 282 cam. :grin:
Zubair wrote:If you can't handle a 288 in traffic, you a learner driver.
Oh my word, I friggin' hosed myself! :lol:
VWicked
Membership No: 1492
Re: 272 vs 276
Post by VWicked » Fri Nov 30, 2012 10:20 am
perhaps my consumption is related to my management of lack of management. With the 288 on the 276 tune the AFR's were lean around 15 or so, so Stephan had to add more fuel to protect the car from itself.
That in mind though, cruising at 120km/h the car chows the same amount of fuel on all the cams i have (Stock, 268, 276 and 288) the onbly difference is when the car idles in traffic that the 288 used to drink.
1992 Golf Mk2 VR6
2009 Golf Mk5 GTi
2015 Golf Mk7 R
Chadsta
Re: 272 vs 276
Post by Chadsta » Thu Jan 18, 2018 8:39 pm
Hi car koppe i just recentlt got me a mrk4 1.6 sr uhm what type of cam is suitable for it and everyday use...
Need help im new at this
ADZ
Car Model: Mk2 GTI 16v
Re: 272 vs 276
Post by ADZ » Fri Jan 19, 2018 8:23 am
Psycho8v wrote:Sorry for the hijack. But I think this can be relevant information to the OP as well.
Hey Psycho8v I've got a 282 cam in my citi with an ADY motor runs absolutely smooth no jerking no hesitation you can pull off and cruise at 1000rpm with no issues, in terms of power it comes in from around 3800rpm and drops of around 6400rpm I'm still running mp9. Fuel consumption is excellent I get around 13 to 13.5km per lt if I drive nicely lol but if I floor it then it drops to around 11km/lt.
Its a good cam for a 2lt, I recently bought a mk2 with a 2e motor running dictator on that one I will go for either the 288 or 298.
02' citi 2L 8v
89' Mk2 1.8 16v GTi
72' Beetle 1600TP
Re: 272 vs 276
Post by panic-mechanic » Mon Jan 22, 2018 10:16 am
There are very few places that makes a cam for that engine. There are actually very few performance upgrades for that engine.
'07 Audi A4 2l TDI
Shadows101Fall
Re: 272 vs 276
Post by Shadows101Fall » Mon Jan 22, 2018 5:50 pm
Chadsta wrote:Hi car koppe i just recentlt got me a mrk4 1.6 sr uhm what type of cam is suitable for it and everyday use...
:lol: Mother of thread Resurrection. Why not go dig up your great grandma while your at it.
I buy broken/smashed/written off cars
Current: 2005 Alfa Romeo GT 1.9 JTDm
Ex: 2014 Nissan NP200 1.6i - meh.. Sold
Ex: 2000 Alfa Romeo GTV 3.0 Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=197077
Ex:1980 2 door mk1 build thread Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=192831
Spoilt01
Car Model: CitiRox 1.4i
Re: 272 vs 276
Post by Spoilt01 » Wed Jan 24, 2018 2:25 pm
Lol im so glad someone opened up this can of worms :lol: I too have a cam question as I would like to add one to my 1.4i, I read many of the older posts and from what I can gather for a 1.4i standard motor with just exhaust (branch and 50mm freeflow) and K+N flatbed the options are:
268 - best for daily, bottom end torq focus and least lumpiness.
272 - middle ground with balance of either and some lumpiness.
276 - biggest (reasonably) for 1.4i stock motor with most lumpiness and least bottom end torq.
Then the decent brands (well I think) is estas and stk, estas being the sort after (their website seems down I sent a PM to nellis and waiting on pricing). stk came back with this package which seems decent price wise... http://stk.co.za/camshaft-shop-online/3 ... -38-detail
Any advise and thoughts that I should look out for or in going this road? Lifter Set & Vernier Pulley? etc etc
