VAG COM / VCDS Register
Mange
Car Model: Ibiza Cupra
Re: VAG COM / VCDS Register
Post by Mange » Mon Oct 06, 2014 10:13 pm
:troll: got me a cable and software !!! ...... only thing i know how to do is do the complete scan and error codes :oops:
i had these 2 come up any idea what i need to do in order to fix the problem ?
....... then just would like to know the needle sweep .. is it possible to be done in the 2006 Ibiza Cupra ?
Current : Ibiza CUPRA 1.8T
2005 Citi 2l 8v *sold*
1983 Golf 1.6 *sold*
Belix
Car Model: GTi 6, Jetta CLX MK2
Post by Belix » Tue Oct 07, 2014 11:07 am
best place to post up errors is on the rosstech section of VWVortex. Just make sure you have a legit cable or they get real sniffy.
Often an error is a one off. Note them, then reset errors and check again in a couple days
Anyone need VCDS coding?
My ride thread: Reflex Silver 2010 MK6 Gti
The old girl: Red 1990 Jetta 2 GLX 3 SPD Auto
MeanTdi
The Imposer Mod-whore-rator
Car Model: Polo 1.9 TDI Sportline
Membership No: 1153
Post by MeanTdi » Tue Oct 07, 2014 2:38 pm
http://wiki.ross-tech.com/wiki/index.php/00929
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00929 - Locking Module for Central Locking; Front Passenger Side (F221): Implausible Signal
Possible Symptoms
## Door Locks not working properly
Possible Causes
## Wiring/Connectors from/to Locking Module for Central Locking; Front Passenger Side (F221) faulty
## Voltage Supply for Locking Module for Central Locking; Front Passenger Side (F221) faulty
## Door Lock Mechanics are stiff/partially seized
## Locking Module for Central Locking; Front Passenger Side (F221) faulty
Possible Solutions
## Check Wiring/Connectors from/to Locking Module for Central Locking; Front Passenger Side (F221)
## Check Voltage Supply for Locking Module for Central Locking; Front Passenger Side (F221)
## Check Door Lock Mechanics/Operation
## Check Locking Module for Central Locking; Front Passenger Side (F221)
00929 - Locking Module for Central Locking; Front Passenger Side (F221): Incorrectly Equipped
Possible Symptoms
Possible Causes
## Incorrect Door Lock installed
Possible Solutions
## Check Locking Module for Central Locking; Front Passenger Side (F221) ## Check Door Lock Part Number
http://wiki.ross-tech.com/wiki/index.php/01598
01598 - Drive Battery Voltage
01598 - Drive Battery Voltage: Signal to Low
Possible Symptoms
Engine not starting
Possible Causes
Battery low
Battery faulty
Possible Solutions
Charge Battery
Check/Replace Battery
Marco
Ride: VW Polo 1.9 TDI Sportline
Belix
Post by Belix » Tue Oct 07, 2014 3:14 pm
anyone got a cable nearby rosebank, randburg except the chop that stole mine? :)
Post by Kyle » Tue Oct 07, 2014 3:17 pm
Where can I get one locally?
Belix
Post by Belix » Tue Oct 07, 2014 9:56 pm
Post by Kyle » Wed Oct 08, 2014 7:41 am
Mange
Post by Mange » Wed Oct 08, 2014 10:58 am
awesome stuff thanks for the reply ... i shall get onto the fault finding then thanks!!
xmesox
Post by xmesox » Wed Oct 15, 2014 4:00 pm
Anyone know someone in the Somerset West area who can help me out that has a scanner? Private or even a well-priced shop? My car has been having issues (dies while driving, regardless of conditions), and I've run through just about every mechanic in town and no one has found the problem, and I've only seen them use hand-held portable diagnostic scanners when checking for problems. Thanks
Johannvisser
Car Model: Transporter 4Motion DSG
Post by Johannvisser » Thu Nov 27, 2014 10:04 pm
Hi guys, I'm in the Mossel bay area, genuine Ross-Tech cable..
Using Tapatalk
Neale
Post by Neale » Mon Dec 01, 2014 11:21 pm
is there anyone is JHB that can:
re-calibrate a the 6spd DSG box
activate needle sweep
and check for errors
all on a 2007 MK5
i am willing to travel to you and compensate you in beer and cash for your help
george88
Car Model: 1.4 DSG PGTi
Post by george88 » Mon Dec 08, 2014 10:35 pm
golfsmith wrote:I have VCDS cable can help,Lichtenburg North West
How much do you charge? Have the 2011 PGTi, it gave a gearbox error yesterday, spanner flashing on the D1, D2... on the cockpit, did a restart to get the ECU restest the components and it was gone after that.
Based in PTA but do visit Mafikeng North West.
Fray
Car Model: '06 A4 DTM, '07 A4 2.0T
Membership No: 1622
Post by Fray » Tue Dec 09, 2014 8:38 am
In Durban, I have VAGCOM and can scan/clear/do stuff
PM me if you need help
Belix
Post by Belix » Fri Jan 09, 2015 10:12 am
Big thanks to NeoSA for helping me out with a bit of coding. Unfortunately it did not work, seems new cluster does not support staging, and looks like I'll need some additional coding to get the TPMS working again, but thanks all the same.
SebastianS
Car Model: Polo Mk4 2.0 8v
Post by SebastianS » Wed Jul 01, 2015 11:25 am
xmesox wrote:Anyone know someone in the Somerset West area who can help me out that has a scanner? Private or even a well-priced shop? My car has been having issues (dies while driving, regardless of conditions), and I've run through just about every mechanic in town and no one has found the problem, and I've only seen them use hand-held portable diagnostic scanners when checking for problems. Thanks
Hey @xmesox
I got hold of a fellow forum member @Titleists, you should be able to PM him here: http://vwclub.co.za/forum/memberlist.ph ... le&u=22575 in the Durbanville area.
Current: '05 VW Polo (9n) 2.0 8v (BBX) (10km/l)
Ex: '13 Honda Brio 1.2 ohc 16v iVTEC A/T (Stock, 13-14km/l, efficient!)
Ex: '98 Opel Astra Euro 2.0 8v (Branches, Adjustable FPR, 10km/l)
Ex: '05 Ford Fiesta 1.4 16v (Cone filter, Powerflow SS Catback with loudest muffler, Tinted windows, Xenon Head and Fogs, awe mei bru)
Ex: '90 Opel Kadett 1.3 ohc 8v (SS Wildcat catback, 40mm drop)
Hoosier Daddy
Car Model: Golf VI GTi DSG
Membership No: 2023
Post by Hoosier Daddy » Wed Jul 01, 2015 11:26 am
In Port Elizabeth.
Scanning, fault codes etc.
My Jaeger: ---
My Dream: Gipsy Danger
My First Love: Lucy
Nikz_tsc wrote:Don't be an elachi bhai
Stompie
Boostleak Guru
Car Make: VW POLO
Car Model: 07' GTI 9n3
Membership No: 1843
Post by Stompie » Wed Jul 01, 2015 11:33 am
Cant remember if i put on here.
Kempton park
Scanning errors/clearing fault codes.
BMW 120D E87
Titleists
Philosopher STIG
Membership No: 1520
Post by Titleists » Wed Jul 01, 2015 6:24 pm
Hey @xmesox
Thanks Seb, have you sorted the problems?
Sent from my VCDS
VCDS changes done by me for a minimal fee
My ex rides:
2013 LHD Scirocco R
2011 Golf 6 GTI
Hobbs
Car Model: GTI MK5 - 248kw 530nm - KO4
Membership No: 1848
Post by Hobbs » Sun Jul 26, 2015 5:19 pm
Neale wrote:Hi guys
all on a 2007 MK5
1 - Needle sweep isn't possible on the MK5 GTI (that i know off) you need the "H" cluster which is on the MK6 and upwards.
2 - DSG reset is possible i can assist if you need assistance (east rand area)
3 - check and clear all errors i can assist with as well.
MK5 GTI KO4
245 wkw
530 nm
Pulse Motorsports
Leonardo53
Car Model: 2011 A3 1.8 TFSI
Post by Leonardo53 » Mon Jul 27, 2015 11:39 am
Im available in Bloemfontein ...
Regards
Leo
0837769757
Burner1144
Post by Burner1144 » Wed Sep 09, 2015 9:38 am
VCDS Pro
Can perform all functions
In Durbs, Upper Highway.
Regards
Dane
0820456482
2005 Subaru STi
2005 Golf 5 GTi
2004 Golf 4 GTi R
2002 Golf 4 GTi
4ePikanini
Car Model: Touareg R5
Post by 4ePikanini » Fri Sep 11, 2015 2:39 pm
VCDS PRO
East London
My Touareg Build
2005 Touareg R5 Air & Bi-Xenon
devan g6
Post by devan g6 » Fri Sep 11, 2015 4:26 pm
Alberton-jhb south Devan 061 474 8407.
stig
Car Model: Polo 1.9 TDi Highline 96KW
Membership No: 2083
Post by stig » Sun Sep 13, 2015 3:01 pm
Hey Leo. What can you program on a polo 9n3?
Sent from my D6603 using Tapatalk
The Ride:
Mods: Uflow FMIC ,Stainless boost piping, RKmotion tuned, 17" Audi A5 Reps, Cobra coilovers, SMF cutch kit
H&M Dyno Night: 114KW 429NM
stormjames7
Post by stormjames7 » Wed Sep 23, 2015 1:22 pm
Whatsup Gents,
Would anyone be able to help me out with re-coding via VCDS to remove the error light from the LED tails i have installed?
I am in Pretoria East.
Your help would be greatly appreciated.
