9n3 Polo - Problem - (ABS)(!) and car resets
- Silverbird_96Kw
- Car Model: Mk7 Golf R
- Membership No: 1643
Ok so I've used the search thingy: but no fix to the problem
http://www.vwclub.co.za/phpbb3/viewtopi ... =3&t=99583
Mine started with the (ABS) and (!) light, checked all the batt terminals and those thats on top off the batt - cleaned them all and attached it again all was fine untill it started doing it again when i went to the shops. When I came back to the car, the car didnt want to unlock with the remote so had to use the key in the door to unlock it, then I saw the car reset itself with the clock etc, now this has been happening now for a while...
Took it to VW the first time it happend and the guy connected his laptop to the car and it showed no errors.
Please help, maybe someone had past experiences of this happening?
15 VW Golf R
15 VW Passat 2.0TSi Rline
17 VW Polo 1.2TSi Highline
17 VW Golf Mk7.5 GTi
15 Audi A3 Sedan 1.8TFSI Stronic
11 VW Roc 2.0TFSI DSG
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
12 VW Golf 6 1.4 TSI Comfortline
06 Vw Polo 1.9 TDI Sportline
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
Re: 9n3 Polo - Problem - (ABS)(!) and car resets
That sounds like power shortage of some sort - check all the power connections and earth straps. There is also one on the power steering.
VGTI wrote:http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=136968
If it's the pump the it will be dead/heavy all the time. Most likely a bad connection somewhere. Bad earth will most likely give other errors too, like ABS etc.
So check the flat fuses on top of the battery and all the sensor cables.
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
- SoDub
- Chairman
- Car Make: Seat
- Car Model: Seat Ibiza Cupra 20VT
- Membership No: 1998
I had the exact same issue! Kept on happening every time I washed the car. I tightened up the earth from the battery and it seems to have "cured" it. My power steering would cut out if I was making a U-turn sometimes and ABS light would flash and ping and I used to get the "locked out of the car" issue often. Try redo that main battery earth that attaches to the body behind the battery on the wheel well and monitor it. It was pissing me off so bad!!!
El Toro
2009 Seat Ibiza Cupra 1.8T(El Toro)
Blossom
2007 Seat Ibiza Cupra 1.9TDi(Blossom)
Turbo Killer Sportline
2007 - Polo TDI Sportline
"I live my life 1 turbo at a time."
El Toro
Blossom
- Silverbird_96Kw
MeanTdi wrote:That sounds like power shortage of some sort - check all the power connections and earth straps. There is also one on the power steering.
Thanx MeanTdi and veedubbed,veedubbed wrote:I had the exact same issue! Kept on happening every time I washed the car. I tightened up the earth from the battery and it seems to have "cured" it. My power steering would cut out if I was making a U-turn sometimes and ABS light would flash and ping and I used to get the "locked out of the car" issue often. Try redo that main battery earth that attaches to the body behind the battery on the wheel well and monitor it. It was pissing me off so bad!!!
Yeah im also getting pissed , going to redo it when i get home, had the power steering light also, but only once and never again... Hope it works
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Can it be possible that he might need a new batery ?? As he said he already checked all connections ??
Just asking / raising the thought
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- Silverbird_96Kw
Oi buddy, well ive got a new one a few months back... But wont hurt to have it check.1FlyTDI! wrote:Can it be possible that he might need a new batery ?? As he said he already checked all connections ??
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
The car would battle to start then.1FlyTDI! wrote:Can it be possible that he might need a new batery ?? As he said he already checked all connections ??
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Black&White
- Car Model: 7R
- Membership No: 1863
Had the same problem, mine was fixed by tightening the cables at the battery properly.
That fixed it for me.
'15 Golf 7R
'13 6R CrossPolo TDI (Sold)
Polo 2.Slow (Sold)
'03 citi life 1.6 ( stolen & retrieved then sold)
'86 mk1 2door CTI (sold)
- Car Model: Amarok V6
- Membership No: 664
When checking the earth straps make sure to check the power steering earth.. quite a common issue on the 9N.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- M@rk
- Car Model: 1.9 Tdi Sportline
- Membership No: 1776
+11FlyTDI! wrote:Can it be possible that he might need a new batery ?? As he said he already checked all connections ??
- Deranged_9n3
- Darth Vader
That's true thanx for that MarcoMeanTdi wrote:The car would battle to start then.1FlyTDI! wrote:Can it be possible that he might need a new batery ?? As he said he already checked all connections ??
My Youtube Channel
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- Silverbird_96Kw
Thanx for all the input and help guys - Ive taken the earth strap out cleaned it and tightened it nicely up again. Hope its fixed now
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
- Car Make: 1.9tdi sportline 9n3
- Car Model: Polo
Hey guys, i have this same issue. Mine is weird though. Drive on a weird incline with a slight turn or reverse down one causing the car fo have an ‘incorrect’ bounce then the abs, powersteering light will illuminate and the car would also idle weirdly. Interestingly when this happens, my trip mileage goes to 0 and that tells me theres a disconnection at that moment at the battery. Switch the car off and back on, the speedo would be dead, repeat process then car starts. I sprayed all terminals with cleaner and anti corrosion stuff, tightened everything and it seems fine now. Just want to know if anyone else’s issue persisted or is it the earth cable thats the devil?
- EX-DOHCTOR
- Membership No: 712
Did you check the blade fuses on top of the battery?
Sometimes they crack in the middle, tiny hairline crack in the middle and this can sometimes cause this weird behavior while driving.
Hello my golf 4 gti abs activates when car speed drops below 20kmh....even if im moving slow we speed drop below 20 the pedal pulses. The abs light does not light up....please help
- Registered for: 1 year
- Car Model: Polo TSI Comfortline
Hi all my polo tsi shows the below errors
error stabalisation
red steering wheel light
break workshop error
doors lock and unlock
speedometer goes to zero then back up
all this while driving. if it happens when i just start the car the the steering wheel is stiff
PS i took it to vw. they told me to change bcu, oxygen sensor and steering rack R25K. i did that and still same problem.
please help as no one at vw or vw sa knows what to do beside tell me now i must change power steering module at 36k which i dnt have. and no refund on 25k
error stabalisation
