Ping Pong
- zain_c
Ping Pong
Hi guys...
So i bought a mk1 gti about 6weeks ago...its really a fun car to drive, goes well and the torque is quite punchy. Fitted a branch and Powerflow zorst so it sounds the part as well.
Only problem i'm having is when i'm highway cruising and floor it will ping From standstill and giving it stick till into 5th there will be nothing. But as soon as I'm driving for an extended period of time uninterrupted and just decide to punch the throttle it pings. Really annoying.
Car idles fine, and fuel consumption is normal...was thinking about fitting a thicker headgasket in an attempt to get rid of it.
No smoking either, fumes smell a bit rich but I've been told its the norm with these cars?
Any other suggestions?
Zain
Zain
2010 Honda Accord K24
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
Re: Ping Pong
How much does it ping? A little? A lot? Very mild or quite loud. Simple case of ignition timing advanced a bit too far, methinks.
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Re: Ping Pong
Turn down timing a tad, also check if your vacuum pipe for the advance is not torn
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- zain_c
Re: Ping Pong
Thanks for replies guys...it quite mild but loud enough for me to hear. The timing is retarded quite a bit running at about 15, these motors should be running at 24-28.Jetta2 wrote:How much does it ping? A little? A lot? Very mild or quite loud. Simple case of ignition timing advanced a bit too far, methinks.
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- zain_c
Re: Ping Pong
Gona have a look this weekend. Thanks. Don't have time in the week to look at the car.VWicked wrote:Turn down timing a tad, also check if your vacuum pipe for the advance is not torn
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- VWicked
Re: Ping Pong
The vacuum pipe should run from dizzy to back of throttle body.
are you saying the car is running 15 degrees timing?
- zain_c
Re: Ping Pong
yip 15deg timing. And surprisingly enough even with the timing retarded that much it still goes well. :-/
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- VWicked
Re: Ping Pong
i'm missing something, we run around 10 degree's at the coast, 15 degree is advanced...
- zain_c
Re: Ping Pong
sorry it was advanced to 10deg and pinged
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- VWicked
Re: Ping Pong
yes so lower it a deg and it will be fine...
- zain_c
Re: Ping Pong
i've lowered it so much that the car splutter coz idle is so low and...it still pings. Ok it's very faint but it's still there.
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- VWicked
Re: Ping Pong
Then adjust the idle up using the idle screw...
I think you need to tune the car. Also are timing marks all correct at TDC?
- zain_c
Re: Ping Pong
yeah i adjusted the idle screw then all is fine...BUT then the car loses some of its aggression! But hey, i'd rather have a tame car than a pinging one.
Plan is to have it tuned, just looking for a place that can do it well, yip all timing marks etc are spot on.
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- vr6zn
- Car Model: 1998 MK3 VR6 Golf
Re: Ping Pong
Did you check the condition of the spark plugs?
Six is always better then four!
1998 Golf VR6 (Durban Stock)
2001 Polo Playa 1.4i
1994 Jetta VR6
1992 1.3 Citi Golf
1994 Jetta VR6
1992 1.3 Citi Golf
- zain_c
Re: Ping Pong
yip i serviced the car about 1000kms ago...so everything is all good.
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
Re: Ping Pong
Add octane booster and see if it goes away.
Re: Ping Pong
Is it the K-Jet fuel injected one like the CTI?
My CTi also had a ping problem. When it is hot (100C on oil temp gauge and water temp in middle) it would ping when you quickly floor it in any gear. Just a slight trrrrt and then a very light pinging sound the whole time up to redline. It was annoying as I am a perfectionist and wanted it fixed.
I eventually had it at a VW specialist shop who fiddled with timing. We even put the timing on 0 degrees and when you quickly pull on throttle cable it will still do that quick ping. They eventually did a trick whereby they put permanent vacuum on distributor and did something to the timing. It was gone but car was very lazy. Fuel economy wasn't effected. But again, car was lazy. 1600's would be able to kick my @ss. My friends 1300 tazz had a 276 cam and cylinder head was gasflowed and skim. It could hold up to me the whole time up to 4th gear
I suspected something in the distributor was wrong but at R4,000 for a new one from Vw I left it with that vacuum trick we did.
Car was eventually sold. Thank goodness.
1977 Datsun 1200GX
Wife's car: 2019 Suzuki Ciaz
1977 Datsun 1200GX
- zain_c
Re: Ping Pong
jeez...yours sounded bad.
Yeah, its the Kjet as well.
Well i can gun my car from the line and it will be 100% even till into 5th. Only seems to ping if i'm driving a constant speed like on a highway and just quickly floor it in 4th or 5th i'd hear the pinging and as it climbing towards the red it will start going away.
I don't plan on selling the car as it's my project and I only pull it out for a drive once in a while. So i can live with it for now.
Even with the timing retarded the car still manages to dust off 1.6 Velocitis with ease.
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
Re: Ping Pong
Comp tests revealed nothing wrong. Constant comp of 9.5 in 3 of the cylinders and for some kind of strange reason (think it is mass production factory cast error) the 3rd cylinder was 10.5
1977 Datsun 1200GX
1977 Datsun 1200GX
Re: Ping Pong
Did you try another fuel? Maybe 95 octane?
1977 Datsun 1200GX
1977 Datsun 1200GX
- zain_c
Re: Ping Pong
Actually planning to try it out soon...will see how it goes.
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
Re: Ping Pong
Just remember that one batch won't give correct testing results. Use at least 3 tanks to get the old fuel out of the sytem.
Hope you come right. 95 didn't work for me and octane booster also didn't work.
I wonder now. I can't remember that my car did it with leaded fuel. Only noticed it with unleaded and LRP.
1977 Datsun 1200GX
1977 Datsun 1200GX
- Car Model: Amarok V6
- Membership No: 664
Re: Ping Pong
Reading some of these post really make me very very concerned..
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- zain_c
Re: Ping Pong
any other suggestions Joggie? I'd like to get rid of this annoying prob...
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
Re: Ping Pong
What cam in there.?
