MK1 Rear brake regulator/compensator
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Hi Guy's
I'll be fitting the rear Koni coils on my Mk1 Golf this weekend, I've read up abit and apparently the rear brake regulator will need to be adjusted due to the car being a bit lower and I also just want to make sure it is set right so that it doesn't suddenly lock when i have extra people at the back or under heavy braking.
Anyone done this before or perhaps know how it should be set?
I do know the spring connects to a sliding nut & bolt, any idea how far along it should sit on the slider?
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- AlexTDi
Re: MK1 Rear brake regulator/compensator
Thanks for chasing Panic away guys! He would of already posted a response
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Colonel
- Membership No: 1041
I've lowered and raised and lowered my car a few times already and has never fiddled with the brake bias, brakes never locked up once with or without load, even on track day.
- AlexTDi
Thanks for the respone bud, It could be the case on your car but it's definitely adjustable for a reason thats why i want to have it set right.UDC wrote:I've lowered and raised and lowered my car a few times already and has never fiddled with the brake bias, brakes never locked up once with or without load, even on track day.
I'm just trying to avoid an issue where i can.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Ian F's special snugglebunny
- Car Model: Caddy
- Membership No: 1548
Same on my brothers car, and it sits quite low.
Never had any lockup issues or any instability.
- General
- Car Model: Golf GT
- Membership No: 1464
Standard 80's Mk1 with high and soft suspension had quite a bit of weight transfer under heavy braking, causing the back to go 'light' and locking up the rear wheels. Stiffer and lower suspension negates this to a large extent, keeping more weight on the back wheels. My Velo came without the compensator and even after fitting disks in the back I never had a problem (with coilies and bigger front disks)
Current rides:
Hyundai - 1.4 Getz (daily)
- ScottiesKJ
- Car Model: 92 Citi Golf
- Membership No: 1144
Set the whole thing mid way with car having half a tank of fuel and a spare tyre in the wheel well , remember to set it with the car on the deck , spring should be just under tension .
axle in lowered position ( wheels on the deck )
regulator is adjusted "as above" & the regulator lever is gently pressed against the actuator
http://www.youtube.com/watch?v=qvDRn3anuuE
video-2
axle is in raised position ( wheels of the deck )
the lever has now adjusted itself away from the actuator
http://www.youtube.com/watch?v=0-13p4pqD9Y
video-2
Ag i decided to come back anyway despite some little shithead.
Install your bits and go for a drive. If the rear locks up under ahrd braking then look at adjusting. If not forget about it. Those things are often not worth whatbtheybare supposed to do anyway and lots of citi/mk1 came without then s well.
- ScottiesKJ
@panic Is it not true as well that to avoid locking up at the rear with rear disk's and no regulator/compensator to make your brake lines at the back equal length? That way making breaking to each disk equal pressure
The two rears are independent and brake line length will have almost no effect at all. If younwere using air then maybe yes but on a hydraulic system it will make basically no difference the couple of cm they can differ. Rear lockup is usually caused by the rear having too much braking power or by something being wrong.
- AlexTDi
I've seen it happen on Citi's alot the whole front dips and the back locks up almost instantly, Thanks for the insight and i'm glad i have a stiff-ass low suspension!Torker wrote:Standard 80's Mk1 with high and soft suspension had quite a bit of weight transfer under heavy braking, causing the back to go 'light' and locking up the rear wheels. Stiffer and lower suspension negates this to a large extent, keeping more weight on the back wheels. My Velo came without the compensator and even after fitting disks in the back I never had a problem (with coilies and bigger front disks)
Guess the low sorts out the issue on his car.vdub caddy wrote:Same on my brothers car, and it sits quite low.
Thats the answer i was looking for just under tension roughly mid way, thanks for the videosScottiesKJ wrote:Set the whole thing mid way with car having half a tank of fuel and a spare tyre in the wheel well , remember to set it with the car on the deck , spring should be just under tension .
video-2
Well welcome back, I guess a test drive will be the only way I must just watch out for the popopanic-mechanic wrote:Ag i decided to come back anyway despite some little shithead.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Membership No: 731
FWIW I never had a problem with the rears locking at that height (much lower than stock already)
I miss those Koni shocks man. Beat the hell out of JOM.
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
"We've all been raised on television to believe that one day we'd all be millionaires, and movie gods, and rock stars. But we won't. And we're slowly learning that fact. So we build VDubs son..."
"Owning a MK1 varies between having sex to getting hit in the balls. Usually several times in one day."
1966 Splitty.
No Mk1 ;(
- Neuk
- Treasurer
- Membership No: 806
Never had an issue myself Alex, even with Fes fully loaded...
- ScottiesKJ
OK then what cause's the left rear to lock up once disk's have been fitted? Reason i ask is a guy i know have had it done and if he braked hard the left rear locks up right away? and has cause the car to spin. Could it be a faulty cylinder?panic-mechanic wrote:The two rears are independent and brake line length will have almost no effect at all. If younwere using air then maybe yes but on a hydraulic system it will make basically no difference the couple of cm they can differ. Rear lockup is usually caused by the rear having too much braking power or by something being wrong.
When i had mine done many years back they did equal length lines as they said "this will prevent this" Ive always just believed this as the car has never locked up on me ever.
Pleasure hope you come right1.9TurboVw wrote:Thats the answer i was looking for just under tension roughly mid way, thanks for the videos
On disc conversion the rear sometimes has too much braking and you moght find they did something wrong. You'll also perhaps find the the right front of his car was not good, ie. shock had failed or spring low or he weighed like maybe 200ks so the crossover weight was really bad. You can't say unless one do a bit of a rear look at something whenmit happens.
- AlexTDi
cool and you drove the exact car properly so it should be fineRoadHaWg wrote:FWIW I never had a problem with the rears locking at that height (much lower than stock already)
Yea these Koni's are the best!
I hear you drive like little miss daisy tooNeuk wrote:Never had an issue myself Alex, even with Fes fully loaded...
*runs and hides*
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- ScottiesKJ
panic-mechanic wrote:or he weighed like maybe 200ks
Thanks for the info Panic learn something new everyday
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
as long as you're not going so low as to pull the seals out of place on the bias adjuster causing a leak, then fiddling with it shouldn.t be necessary
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- Car Make: mk1
- Car Model: GTX
@Panicmechanicpanic-mechanic wrote: ↑Fri Jul 13, 2012 10:44 am Those things are often not worth what they are supposed to do anyway and lots of citi/mk1 came without them as well.
ON my 94' Fox it started to leak from the bias valve. Is there a kit to replace the rubbers or should it be replaced as a whole or can it be deleted all together.
Thx Jaco
Yes there is a rebuild kit
Yes you can replace it as a whole
No don't delete it unless you rpalce it with something else that is adjustable.
