Polo 2003 (9n) 1.6i 8v - Timing
- Zap 679
- Car Model: Citi Golf 1.6
Hi,
Im looking for the timing marks on the 9n 1.6i 8v Polo...
- Zap 679
Re: Polo 2003 (9n) 1.6i 8v - Timing
Any one please?
I've search the web but only find the 1.4 16v from oversee.
what engine code.
- Zap 679
Engine no. : BAH 104
did one a while ago and now for the life of me cannot not recall what the markings looked like. Ignition was pretty much fixed if I recall right and the cam was pretty obvious. So basically just turn the engine by hand and see till you get tdc on the crank and then look for the others.
- Zap 679
I will try to load some pictures
- grease monkey
- Car Make: Golf
- Car Model: MK2
This what you looking for?
- grease monkey
- Car Make: Golf
- Car Model: MK2
- Zap 679
YES!!!
Thank you grease monkey!!
Hi there,
I did my 2004 Polo 1.6 8v BAH 9N engine a week ago from bottom up.
Rings STD, Bearings Agents, Rear Oil Seal Agents with built in Trigger Ring, Front Seals Etc, water pump, cam belt, plug leads, plugs.
Car starts up fine idle just below 1000rpm, Vag indicates idle at 800rpm and 15 Degress BTDC.
Problem: The car drives fine at times then all of sudden it bogs down like loss of spark then picks up again after 2500rpm moves like bullet. It battling on lower take off with alot of hi cups which is intermittent...
I set the Trigger wheel pilot hole at 12 o clock, and front crank gear notch to first mark to the left of the oil pump. Also re aligned the throttle body.
any ideas ?
any ideas ?
Tuesday 7 August 2018 18:21:09
032 906 032 E ME7.5.10 2502
Group A: '001 Group B: '002 Group C: '003
RPM Temperature Lambda Bin. Bits RPM Load Inj. On Time Absolute Pres. RPM Absolute Pres. Load Ign. Timing
TIME TIME TIME
Marker STAMP /min °C % STAMP /min % ms mbar STAMP /min mbar % °BTDC
0.4 800 64 -25 10111110 0.8 800 27.8 2.87 420 0 800 420 3.5 5.3
1.6 800 64 -25 10111110 2 800 27.1 2.87 420 1.2 800 420 3.5 6
2.91 760 64 -25 10111110 3.41 800 27.1 2.87 420 2.51 800 420 3.5 5.3
4.21 800 64 -25 10111110 4.61 800 27.8 2.87 420 3.81 800 420 3.5 3
5.42 800 65 -25 10111110 5.91 800 27.8 2.87 420 5.01 800 420 3.5 3
1 6.71 760 65 -25 10111110 7.2 800 27.8 2.87 430 6.31 800 420 3.5 2.3
8 800 65 -25 10111110 8.4 800 27.8 2.87 420 7.61 760 420 3.5 3.8
2 9.2 800 65 -25 10111110 9.6 800 28.6 3.28 430 8.8 800 420 3.9 3
3 10.4 800 65 -25 10111110 10.8 800 27.8 2.87 430 10 760 430 3.9 6
11.7 800 65 -25 10111110 12.1 800 27.8 2.87 420 11.2 760 430 3.5 6
12.9 800 66 -25 10111110 13.3 760 28.6 3.28 440 12.5 800 430 3.9 1.5
TIME TIME TIME
The log u posted is very hard to read. U rather convert that into a spreadsheet on excel and take a pic of it. There are other ways of loading a log onto the forum (i dont how to do it)
Firstly, the hole on the rear main seal should not be lined up directly with the hole on the housing.
On the seal housing, theres a little notch on the lhs of the hole which the hole on seal must be aligned with.
The rms normally comes with a small plastic aligning tool, i dont know if an oem 1 would though.
Theres a post somewhere on here with more info on this.
The front end should be aligned with "2v" on the oil pump housing. i cant remember whether its the first or second mark.
Are u getting any timing or crank/cam sensor dtcs?
Hi Guys,
So is the crank pulley need to reflect on the 2v mark?
I have set mine on to the dot (cant remember if it was 2v or 4v but its the one with the line and then the dot) and checked the first piston, it seems to be TDC but i had to set the cam pulley by teeth clockwise in order for the car sensor fault to go away.
The car runs smooth when cold but as it heats up there is a slight back fire when releasing the accelerator, fule consumption went from 100km / R100 to 50km/R100.
Please help
Please help
the fuel price went up. Rand per kilometer is not a good fuel consumption measurement
yes i do understand that,
Problem is the car is over fuelling, i dont know why but its like puffing unburnt fuel out the exhaust
Check ur fuel trims and work from there
You could have the incorrect filter in. There is a 3 bar and 4 bar filter. Often people get the wrong one and don't check what came out.
