Worth fitting VR6 motor in MK1 Golf???
- Donnie Darko
- Colonel
- Membership No: 1834
Hi Guys
I am toying with the idea to fit a VR6 motor into my mk1.
Currently have a 1.8 8v carb.
Is it worth even looking at???
Or do i just fit a 2.0l motor and modify that?
Ex: 2016 BMW M4
Ex: 2016 Audi RS3 8V
Ex: 2016 VW Golf 7 ED40 Clubsport DSG
Ex: 2012 VW Golf 6 ED35 Manual - 342WHP and 500NM
Ex: 2015 BMW F21 M135i Sport Auto - 393.2WHP and 639NM
Ex: 2013 BMW F20 M135i Sport Auto - 332WHP and 626NM
Ex: 2012 Golf R DSG - 300WHP and 473NM
Ex: 2010 Scirocco DSG 155KW - 300.8WHP and 416NM
Ex: 2008 Ford Focus ST - 262.2WHP and 425NM
Ex: 2006 Golf 5 GTI DSG
- Puni
- Car Model: Touareg V10
- Membership No: 1523
Re: Worth fitting VR6 motor in MK1 Golf???
Bought the PVW this weekend.
There is a guy Nash that is building a MK1 R32 twin turbo. They call it the Nasty Rabbit. Will check if I can find a link.
But hell this guy put a lot of work and time and money into it.
Puni
Puni
Derrick Puni Brummer
'08 Touareg V10
'11 CC 2.0 TDI DSG
'17 T6 Kombi 2.0 TDI
Puni's GTI
Puni se Polo
'04 Chico Golf
VWCSA Membership Number: 1523
'08 Touareg V10
'11 CC 2.0 TDI DSG
Puni's GTI
Puni se Polo
'04 Chico Golf
- Post Whore
- Registered for: 17 years
- Car Model: boat
- Membership No: 1133
- Puni
Whydood786 wrote:no
'08 Touareg V10
'11 CC 2.0 TDI DSG
Puni's GTI
Puni se Polo
'04 Chico Golf
'08 Touareg V10
'11 CC 2.0 TDI DSG
Puni's GTI
Puni se Polo
'04 Chico Golf
- Eternal Newbie Post Whore
- Car Model: MK3 GTI 16V
The thing will understeer like a ****, would it not. Such a heavy motor in such a small light car.Puni wrote:Whydood786 wrote:no
- Puni
'08 Touareg V10
'11 CC 2.0 TDI DSG
Puni's GTI
Puni se Polo
'04 Chico Golf
'08 Touareg V10
'11 CC 2.0 TDI DSG
Puni's GTI
Puni se Polo
'04 Chico Golf
ABF motor = +-140kg
1.8T 20V motor = +-150kg
12V 2.8 VR6 motor = +-170kg
Not that much heavier than the others actually. Main problem is that the other motors lean over backwards in the engine bay making the mass more centralised over the driveshafts while the VR leans over towards the front.
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
It has been done but it isnt just a simple engine swap. You will be engine and gearbox, modded side shafts and then theres the fabrication required to get it to fit into a mk1 engine bay. Budget around R50k for this attempt.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Donnie Darko
- Colonel
Oh ok
Any advice on a decent motor to put in that i can modify?
Flow head etc...
Do i stick with 8v or move to 16v?
Flow head etc...
Ex: 2016 BMW M4
Anything is possible with the right money/skill/time/etc.
If you really want a Mk1 VR6, do it. It might not the the best track toy but who cares (if that's not want you want)?
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100, '79 Golf LS
- VWicked
depends on your budget.
You can fit 2.0 8v for around R4500 for the motor and then do some headwork and a cam with a decent management and it will set you back around R12k.
You can go fit 2.0 16v ABF for R10k the motor and do same stuff but then cams etc are more expensive as there are two so budget around R20k for a worked one.
- Car Make: Opel,VW, Ford
- Car Model: Corsa, Citi, Figo
- Membership No: 1995
There's a Caddy with VR6 turbo running around in Sunward Park...
Nothing's impossible - it just costs more
I used to have money.... But now I have a Racecar!!!
- Post Whore
- Car Model: boat
Most turbo vr6 swaps make under 2002k2, I have seen 16vs make more for less, so rather go with what works for sure, unless you have too much money to waste, then be different
- SHAUN
- Post Whore
- Car Make: BMW
- Car Model: 2006 335i
- Membership No: 1148
There was a VR6 turbo in a mk1 at the rock raceway on saturday. Fills the engine bay nicely.
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
- Car Model: 1988 Jetta mk2 cli
Bru if thats what you want, then go ahead and do it. Nobody is going to stop you. People will tell you its not the smartest choice, less power more money blah blah blah, but **** it if we all did the sensible thing day in and day out we would probably still be living in caves huddles around the fire saying hmmmm this isnt too bad. If you can find a gearbox then i say go for it. You will have to get custom side shafts made and make up your own mounting and what not. but yes it is possible and yes it does fit.Just.
i know of a vr6 mk1 that will be for sale soon,,,,,
when in doubt-flatout!
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
If all labour done by urself yes R20k is the budget for a stock one.VWicked wrote: You can go fit 2.0 16v ABF for R10k the motor and do same stuff but then cams etc are more expensive as there are two so budget around R20k for a worked one.
I did mine all myself and worked out R17k and I had all the FI bits already in place and got ABF for R8500.
So add some more for tank, fuel pump etc.
I would love a Mk1 VR. Im sure it will still go better than a 2.0 8V.
If your budget says OK. DO IT!
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
2007 Audi S3
EX
- Smok3X
- Registered for: 15 years
- Car Make: SEAT
- Car Model: LEON CUPRA 2.0 TFSi K04
- Membership No: 3083
Dont do it.
When you eventually get pulled over, your car will be impounded.
Thats a fact and nobody can change it...
You will live with the fear of losing your car every single day it leaves home!
Unless its a dedicated track or drag car... Dont do it.
An ABF has similar risks, but will make similar power for alot less.
My 2 cents... up to you.
Leon CUPRA - 2.0TFSi K04--> Rides Thread
169WKW@Dark Artz - Stock
229WKW@Dark Artz - RevO 2+
Ibiza CUPRA - 1.8 20V - Hybrid Turbo-->Rides Thread
Revo:182KW and 399NM@Experience
ABF Citi Golf - 2.0L 16V--->Rides Thread
FRC - 124KW and 198NM@Auto Trix
1/4 Mile:14.61s
1ST Place - 4AF2 Margate 31st Oct 2010
1/4 Mile:14.61s
- Mc3103
- Car Make: Tuk Tuk
why will it be impounded? Even if he goes through the correct registering procedures?Smok3X wrote:Dont do it.
'96 Citi Sport 1800
'96 Citi Sport 1800
Vodka wrote:Ahh If it's got tits or wheels It's going to cost you money!!
- Car Model: GOLF 4 CABRIOLET
- Membership No: 1841
rather go the 16v route. cheaper in the long run. VR will cost you like they say around R 50k to do properly...
"on the 8th day God created a HONDA, on the 9th day he traded it in on a VW"
- PoLonY
- Car Model: A8
- Membership No: 1997
Durban cops reckon its too powerful for a citi golf...Mc3103 wrote:why will it be impounded? Even if he goes through the correct registering procedures?Smok3X wrote:Dont do it.
- Neuk
- Treasurer
- Membership No: 806
I would do it but for very different reasons than just getting more power...
Then they should start impounding almost all superbikes...PoLonY wrote:Durban cops reckon its too powerful for a citi golf...Mc3103 wrote:why will it be impounded? Even if he goes through the correct registering procedures?Smok3X wrote:Dont do it.
- Smok3X
- Car Make: SEAT
Guys, lets be realistic here...
Cops are not THAT stupid.
Its a V6... Lets say that one more time... a V6 in a Citi Golf!
and even though we all know that it isnt really that much more powerful than an ABF and that the conversion has been done succesfully many times with great results!
When the Police see that, they just go absolutely crazy! Well, atleast in Durban anyway and the thing is, you cant blame anyone for it or say they are unreasonable... its a V6 in a Citi Golf, you REALLY REALLY dont have to be a genius to figure out that it was not meant to be there.
Trust me, I know of more than one guy in Durbs that had a FULLY registered MK1 VR6, all the papers in order and once caught at a roadblocck, that was it! The car will be get an ADMIN MARK against it and forget getting a disc after that...
Yes, there are dodgy, expensive ways around that... but its still a continous risk every time you drive it on a public road... and once the cops in your area know about it, thats it! You will have to remove the motor or lose the car to the pound! It has happened to guys in Durbs with ALL papers in order!
Even if you try and be smart and go legal with the guys... eventually even a judge will tell you to get lost man, its a V6 in a Citi Golf!
Like I said, up to you, but I personally feel it just is not worth it for a car that is used daily...
I would love to have a VR6 Citi for drag! What a beast and wat fun! But NOT for a daily guys...
1/4 Mile:14.61s
1/4 Mile:14.61s
- SHAUN
- Post Whore
- Car Make: BMW
OK so a 20VT in a citi golf is still fine then? the boost pipes and intercooler and copious amounts of more power will not throw the cops off at all, aslong is its not a 6 cylinder?Smok3X wrote:Guys, lets be realistic here...
Oh and its a 6 cylinder, not a V6!!!
- Voora Molester
sooooooo a 2L16V turbo with NOS is fine, but a vr6 in a mk1 isn't?Smok3X wrote:Guys, lets be realistic here...
Thupercharged S4
