Official 6R Polo GTI thread
- Registered for: 6 years
Re: Official 6R Polo GTI thread
Sup guys any reliable software I can get my polo 6r gti flash done in Cape town
Is there no 6r gti crews I can join
- Car Model: Golf MK7 GTI
- Membership No: 3065
Nice Ride man,Zombie0nfire wrote: ↑Tue Mar 13, 2018 1:04 pm Hey everyone
Finally managed to save up and get my 6r gti in december and I LOVE IT is an aftermarket air intake worth it?
I also want to get a dp for some beautiful dsg farts recommendations?
i would do a dp first, worth every penny. Intake you might have to do software at the same time as your check engine light might come on after installing.
2015 Golf MK7 GTI
2015 Golf MK7 GTI
Hi there so tell me what u all done to your polo thinking of maybe going dp Induction
hi guys
please advise....polo gti 1.8 cooling water system problem
just did engine overhaul now the coolant is bubbling in the coolant reservoir,,I checked the compression its fine no blown gasket,,,,I bleed the cooling system and did a coolant flush....replaced the water pump...put in new thermostat but the problem continued and then I took out the thermostat and to my surprise the problem subsided, the fans are kicking in normally and the bubbling in the coolant reservoir has reduced I mean this is on a system with no thermostat the engine heats up normally no fluctuations on the temperature gauge,,,so do I continue to run the car without a thermostat??
second issue on the coolant sensor the two pin sensor on the engine ,,,it shows an intermittent error on obd scan got a new sensor but still the error was showing then I traced the wires and the I found that the sensor is not getting the 5V signal ....im still trying to trace were the wires could have short to ground but I understand this sensor its only for fuel management system it does not have an influence on the first issue I pointed above or please correct me if im wrong?? as my understanding is that the temperature gauge on the cluster is received from the 3 pin temperature sensor next to the radiator ....and on the scan the two pin temperature sensor is always at -48 degrees even though the cluster gauge temp has got to 90 degrees.......kindly please assist me on this issues.
- Preggz
- Car Model: 06 Velociti & 13 6r PGti
Hi Guys
I'm driving a 2013 Pgti
I recently notice while driving at a constant speed and if I had the need to increase speed the car will act up like has it have a miss.
like a sort of a jerk until I leave the accelerator. if I keep my foot down it will give me
Flashing Check Engine/Engine Malfunction or Electric Power Control... soon as speed drops its gone.
would like to know if anyone experience this...
and what was or could be the cause
Thanks in advance
Preggz
Thanks in advance
Preggz
LöW Ridër Velociti
JOMs FTW
Reflex Sliver Polo 6R GTI
HnR Springs
Dp
Forge Intake
SW (Dark Arts)
- Neuk
- Treasurer
- Membership No: 806
Stay safe out there...
- Car Model: Polo 6R GTI
Thanks for the kind words man!XYDER wrote: ↑Thu Jun 21, 2018 8:53 amNice Ride man,Zombie0nfire wrote: ↑Tue Mar 13, 2018 1:04 pm Hey everyone
I got an exhaust done and I absolutely love it, you were right, it was worth every penny.
I see some some guy asked about a 6r gti crew and you sent him a pm.
I am interested and was hoping you could also send a pm my way
Currently Done:
- Golf GTI 35 Edition 17" wheels
- Eibach Pro-Street S Coil overs
- Custom Exhaust From Pires Motorsport
- OEM WRC Front bumper
- Forge DV Spacer
- VW Racingline Intake
- 2002 Mini Cooper 1.6 CVT Automatic
- 2014 VW Polo 6R 1.6 Tiptronic
Check PMZombie0nfire wrote: ↑Tue Jul 10, 2018 12:30 pmThanks for the kind words man!XYDER wrote: ↑Thu Jun 21, 2018 8:53 amNice Ride man,Zombie0nfire wrote: ↑Tue Mar 13, 2018 1:04 pm Hey everyone
2015 Golf MK7 GTI
- Preggz
Hi Guys
do anyone know what spark plug does a stock 6r Gti takes
LöW Ridër Velociti
JOMs FTW
HnR Springs
Dp
Forge Intake
SW (Dark Arts)
