golf mk1 horn staying on
Posted: Mon Feb 27, 2012 7:34 pm
by araf69
Tried to put dual hooters today. Wired it up with the relay. But when I put the key on. The hooter says on without pressing the button. Tested the wiring with a test light, seems the problem is with the steering wheel and power is coming from there when the ignition is on. Anything to look for that touching on the steering?
I did remove the steering wheel to put an ignition switch. Old hooter was disconnected at the time but was working with the same steering wheel.
Re: golf mk1 horn staying on
Posted: Mon Feb 27, 2012 7:57 pm
by otti
seems like your steering coloum gets ground to me, check the penetration through the firewall if it contacts there!
maybe you clamped a cable....
Posted: Mon Feb 27, 2012 7:59 pm
by KID'K
If you suspect anything on the steering wheel, check the gold contactors in between the steering wheel and the ignition column. Check if there’s no metal contact between the two, if there’s any foreign object making the two to contact remove it. Otherwise verify your hooter wiring. If the problem persists get an auto electrician to check it out for you.
Posted: Tue Feb 28, 2012 7:35 am
by panic-mechanic
You do know that there is always power on the hooter circuit when the ignition is on and that the steering wheel button grounds the circuit to make it work?
Posted: Tue Feb 28, 2012 7:50 am
by araf69
Thanks panic did not know that? Should I try another steering?
Posted: Tue Feb 28, 2012 7:52 am
by panic-mechanic
No perhaps have a little look at your wiring?
Posted: Tue Feb 28, 2012 8:47 am
by SJP100
Hope this helps
Posted: Tue Feb 28, 2012 9:56 am
by araf69
That's helps a lot. I do have an earth running of the horn currently and not the button, is that the problem?
Posted: Tue Feb 28, 2012 11:18 am
by Torker
araf69 wrote:That's helps a lot. I do have an earth running of the horn currently and not the button, is that the problem?
If you take the earth off does the horn stop? If so, that is your problem.
Posted: Tue Feb 28, 2012 12:22 pm
by araf69
I tried that yesterday the horn goes off when I pull out the earth. Where must I put the earth. I did mount the earth on the body in the engine bay.
Posted: Tue Feb 28, 2012 12:35 pm
by Torker
araf69 wrote:I tried that yesterday the horn goes off when I pull out the earth. Where must I put the earth. I did mount the earth on the body in the engine bay.
The earth must be switched through the hooter button on the steering wheel. When my horn stopped working I pulled in a seperate wire to a button on the dash and used that instead of the button on the steering wheel.
Posted: Tue Feb 28, 2012 12:36 pm
by SJP100
There's your problem. You should just supply the positive, the horn button supplies the earth.
Posted: Tue Feb 28, 2012 2:09 pm
by araf69
where must put the earth then? or does the button have the earth. Have tried that but then nothing happens when I press the button when I pulled the earth out.
Posted: Tue Feb 28, 2012 2:14 pm
by Torker
araf69 wrote:where must put the earth then? or does the button have the earth. Have tried that but then nothing happens when I press the button when I pulled the earth out.
There is an earth strap from the body to the steering column inside the engine bay - make sure it's intact. Also on the back of the steering wheel there's copper slip rings with fingers that get the potentials to the hooter button - make sure it's making proper contact there...
Posted: Tue Feb 28, 2012 4:15 pm
by araf69
My old hooter worked fine before this. The only thing that I did was remove the steering column to put a new ignition switch. those springs on the steering shaft important? I didn't put then back
Posted: Tue Feb 28, 2012 7:20 pm
by araf69
Steering Shaft seems to problem. Its too wobbly. Can it be that? Does the spring in the steering shaft play a role somehow?
