Which 84mm BMW pistons and what's needed to make them work?
- Registered for: 18 years 9 months
Apart for the valve cuts...For a tall-block n/a 16v?
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100, '79 Golf LS
Re: Which 84mm BMW pistons and what's needed to make them wo
Apparently 328 e36.
Thanks Stephan.panic-mechanic wrote:Apparently 328 e36.
From what I can see on the KS Electronic Catalogue it has a compression height of 32.7mm vs ABF at 29.8mm and a 22mm pin vs 21mm for ABF...so I assume that's what needs machining.
- Donavan
PM marunu (excuse the spelling) he will be able to tell you.
Audi A4 B8 2.0T - Daily
Thanks, did.Donavan wrote:PM marunu (excuse the spelling) he will be able to tell you.
I'm leaning towards the Nissan CA18 pitons at the moment...my block is 83mm and I do not really want to go 84mm.
- Solo786
- Car Make: Porsche,BMW,VW
- Membership No: 1251
Are you trying to build a 2.1?
No, 2L...Solo786 wrote:Are you trying to build a 2.1?
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
whats the benefits of doin this? i mean you increasing capacity not even 100cc.
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
2007 Audi S3
EX
- Abnormal
- Registered for: 20 years
- Membership No: 848
every little bit adds up
\Oo) \ _w_ / (oO/
I'm not doing it to gain, I'm going from turbo bottom-end to n/a. KS 16v n/a are more than R4k if you can get, the BMW and Nissan pistons are less than R1.5k...83mm is standard on the Nissans and 84mm on the BMW ones.CRASH_IT wrote:whats the benefits of doin this? i mean you increasing capacity not even 100cc.
- Registered for: 15 years
I had a discussion with sarel the other day regarding this, if memory serves i recall compression ratio's as high as 14-1 with the nissan pistons fitted
It depends on which nissan piston you are talking about wit ark. There is a very nice piston from the CA 18 that will not bump your CR that high. ALL of the 'other' pistons though will need some sort of machining and rebushing of the conrod ifyou are using the longblock.
- Criminal Troll.
i know completly off VW but i can add some info here.
I built a honda B20 vtec (2.0L)
with CA18 pistons (40 thou) which were 84mm, they were the CA18DE pistons, the normally aspirated with a domed crown, comp would have been crazy high, but i got them machined down and valve pockets machined in, it dropped the compression down to around 11:1 with enough Piston to Valve clearance for STG3 cams.
The only other mod i had to do was get the rods bushed with 1mm copper bushes for the gudgeon pin of the pistons.
All in all it cost me R1300 including pistons and all machining!
Car made 142kw ATW in dbn with stg2 cams
Yes, there are domes ones and flat-top ones. I'm after the flat-top ones, which I think is CA18DET.
Domed:
Flat top:
Domed:
Flat top:
Those are the ones i was talking about. The flat top 83 mm. Semi forged piston.
- Criminal Troll.
here the pistons machined
- CRASH_IT
- Car Model: 8P S3
very interesting.
Im sure with higher compression comes a small gain in power also.
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- Car Model: Citi golf
these bmw e36 328i pistons are they 84mm or 84.5mm? what sorta compression ratio would that give on a abf motor?
- 16V Dub
- Car Model: GOLF 1
Hwzt guys...
I've been playing around with the BMW pistons and the CA18 domed Nissan piston for my current build.
The BMW piston is 84mm, with alot of machine work needed.
The Nissan piston is 83mm wit little work needed to work on a 2.0lt 16V high compression build.
I settled with the 40" nissan piston (84mm). I'm looking at about a 12+ compression ratio...
Daily Ride / Tow Vehicle : Citi Golf, 2.0lt 16V, Auto...
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=131489
Drag Car : 2.0lt 16valve Golf 1
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Sorry for the hijack but do you have the compression height and dome cc on those dome nissan pistons?
They seem perfect for a fsi head swap.
- Wheel Whore
- Car Model: mk2 gti 16v exec
im running those (semi forged) nissan 83mm pistons, they work but cant take revs, they show scuff marks on skirts. wont work in 20v, you would need higher compression than flat top.
() they are anodised, will need to machine for valve clearances
In your 16v? How much do you rev to and how frequent?zaahir wrote:im running those (semi forged) nissan 83mm pistons, they work but cant take revs, they show scuff marks on skirts. wont work in 20v, you would need higher compression than flat top.
Why would you say a dome piston is needed if ADR use flat top pistons?
- Wheel Whore
16v revs to 7800, every race meeting.
How much power does adr make?
92kW stock IIRC...so not much at all.zaahir wrote:16v revs to 7800, every race meeting.
So you have any suggestions for an alternative? Are you running pump fuel and what's your CR?
How's 10.5 cr?
