Citi 1.4i not revving
howzit guys,
i used my citi 1.4 this morning and all was good.
then all of a sudden it did a backfire sound and cut out.
it starts and idles fine... but as soon as i rev it cuts out.
if i rev really slowly and get it past 2500revs it revs perfectly. what could be the problem?
anyone here know?
anyone here know?
- Car Make: SEAT
- Membership No: 478
Re: Citi 1.4i not revving
Hey man.zi wrote:howzit guys,
anyone here know?
Either water temp sender or coil.
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
thanks bud.... ill start with the coil...
- Colonel
Could be fuel pressure as well, broken rail? Water temp sender will just make it go rich shouldn't stop it from revving up ...
i just removed the 4 pin wiring plug from the water temp sender and the car had a very lumpy idle. i then removed the water temp sender and put it back now the car idles lumpy and cant rev at all. idle is gone very lumpy.
i think ill replace the water temp sender and then the coils... i hope its not a broken rail that sounds expensive
i should have mentioned , there was a tiny puddle - (very very small) i drove through but i checked and double checked the distributor and the leads all are dry. do u guys think i should just wait a little to make sure everything is 100 percent dry?
can someone tell me if the red circled part is the coil? i see its sparking when the car idles...
i seem to have confused distributor with coil
- Car Model: Citi Golf 2.0l 8v
- Membership No: 1674
Sounds very similar to when my fuel rail went, try take the fuel pressure regulator off and move the inner pipe of the fuel rail around, if you feel it moving or hitting the outer pipe then its probably that.
Cost a little over R1000 for mine from Goldwagen, but if you look around Gumtree enough, you might find one too.
Edit: Another easier way to check, is to block the rubber fuel return line with pliers or something, if the car does idle better, then its probably fuel pressure and most likely the rail
2006 Citi Golf 2.0L 8v
- MhVW
- Car Model: '06 Polo Classic 1.9 TDi
- Membership No: 1466
That's the coil!
If you can see sparks at the coil on idle and the HT lead is not damaged, the insolator on the coil might be damaged.
Replace the coil in that case.
- Colonel
+1MhVW wrote:That's the coil!
thanks for the replies guys.
Went to goldwagen and got a new coil.... car wouldn’t start at all. Goldwagen exchanged unit for another one and all is working 100% now.
thanks again guys i learned something new today.
- Car Make: SEAT
Depends which way it fails... if the sender is telling the ECU that the water is hotter than it actually is then it will lean out the mixture. I have had this on 2 different cars. The one wouldn't start at all and the other one would start and idle (albeit very rough) and as soon as you tried to rev it, the motor would die. A new water temp sender fixed both cars.neighbourhood terror wrote:Could be fuel pressure as well, broken rail? Water temp sender will just make it go rich shouldn't stop it from revving up ...
Zi, yes if you can see sparks when the car is idling then the coil is cracked (usually happens when water gets sprayed on it when it is hot).
I had this on my friends Polo and it had the same symptoms as your car.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Registered for: 3 years 8 months
Hi guys, I have a Citi Golf 1.4i sport MK1 (AGY motor) - have just rebuilt the head after overhauling the motor. Started the car and it will not rev past 3000 rpm.
The car is very sluggish, it sounds like it is starving or the timing is out - BUT - The timing is spot on, we have replaced the coil, distributor, water temp sensor, checked the fuel rail, swapped out the fuel pressure regulator, MAF sensor, checked fuel funnel and inside tank etc.
I am inclined to think that the problem lies in the timing but it has been checked and rechecked, redone a few times now - it's as if its' not advancing the timing.
Any thoughts will be appreciated!
- Car Model: mk3 jetta 3
hi guys i have a 1995 jetta 3 mk3.
gone sluggish after mechanic did idk wat to it.
i did timing myself. all indicators match.
car is a conversion and theres NO MAF(mass air flow)sensor.
my friend added a cold intake in his golf 1 and doesnt have MAF connected but car still runs fine.
i changed
coil about a year back. today i cleaned corrosion
Spark plugs today
leads today
and car still jerky and bearly goes over 100km with foot flat to ground.
before this i use to rip 325i gush before in a robot to robot
car has mods of racing fly wheel bigger pistons gti cam
please help its really depressing after a days work and still no luck
i changed
Spark plugs today
leads today
Start your own thread, we will help you there.Lonzo wrote:hi guys i have a 1995 jetta 3 mk3.
i changed
Spark plugs today
leads today
Mk3 is not a simple thing to fix like a Citi.
Mention me in you first post by adding the "@" in front of my name, explain in detail what has been done and the community will try to help.
missioner wrote: ↑Fri Apr 09, 2021 9:38 pmStart your own thread, we will help you there.Lonzo wrote:hi guys i have a 1995 jetta 3 mk3.
i changed
Spark plugs today
leads today
howsit man. fixed !!!
changed my batteries and fuel pump.
fuel pump wasnt dead but was going!!!!
new fuel pump in. car flying and batteries are on its way out. as much as it showing 12.70v was loaded drops to 10V. WEIRD
