2l .8v with dicktator citi
- Car Model: mk1 1979 gts 2l
hey guys i have huge problem my car wont idle after driving it hard it just dies and also when the car is hot and i turn it off and try start it again it wont start (no spark ) if i leave the car for a while +/- 30 min then it starts again like nothing was wrong????? please help
- Car Model: Amarok V6
- Membership No: 664
Re: 2l .8v with dicktator citi
Coil or TP100 ?
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
Could also be the Hall sender on the dizzy. Can't remember if one can see the signal on the Dictator ?
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
coil ... would that be the flashing green light on the dicktator?????
im guessing its the dizzy i changed out the coil and put a new one and the same thing happened......... could it be the dizzy?
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Just a thought, is there no immobiliser kaking around? I know my mates 16v mk2 did this after you drove a while it just would start and it was his alarm stuffing around.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Car Make: Seat
- Car Model: Ibiza Cupra
possibly the dicktator not set up correctly ...... ??
Current : Ibiza CUPRA 1.8T
2005 Citi 2l 8v *sold*
1983 Golf 1.6 *sold*
no alarm is in the car .... please help its driving me mad i cant even stop to put petrol in
Could be the hall sender on the dizzy yes.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Major-General
- Registered for: 21 years 2 months
- Car Model: MK1
Check Hall wiring +0- are all connected properly, I had issue when I installed mine recently(first time management install) and also had no spark. As Joggie mentioned, could be the hall sender itself. Also check the Dicktator user manual for where the idle parameters,idle control setup should be,trigger edge settings should be on falling and lastly make sure TP100 is earthed somewhere to body.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
its a coil not tp100
Explain please ... we don't know the exsact way you did your install.
If it's a round cyl. type coil there has to be a tp100 somewhere to fire the coil . If you have ove of the newer Coil packs or something like the later 9N polos then you don't need a TP100 as it's basicly build into the coil pack.
Give us more info on your build so we can help find the problem.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
How hot is the coil at that point. Could be that your dwell is set too long and busy frying the coil.
i dont know mmmm i dont have the time and money to change to tp100 at the moment =(
- jetta786
- Car Model: MK5 JETTA COMFORTLINE 2LTR
- Membership No: 1715
mmmm, me not understanding. why would you want to put in a tp100? if you have the coil with built in module then what is the problem?
on a serious note, I had a problem where by the car woud just cut out. no spark and this was on a mk3 2ltr. this was a intermittent problem and as a result it was very difficult to diagnose.
to cut a long story short. the dissy was the culprit.
its a new coil off so there is no tp100 just waiting till the end of the month for some money then first thing im gonna do is put in a new dizzy and see if that solves the problem thanks for all the advise guys Much appriciated
Do you have a comms cable and the program. If at that stage you can still see rpm while crancking the engine then it can't be the dissy. Don't spend money on guessing at something. Diagnose it properly......
- jetta786
- citiROX
- Car Model: 2020 MK7.5 GTI TCR 36/300
So I went through a couple of posts here. Since I had a similar problem.
Found the problem and fixed it. Was frustrating since I wanted to do it myself and not take it to a shop.
Problem was.
It was very rainy. Golfs are known to have issues when it comes to wet conditions. It would start missing spark, struggle to iddle and die... Was usually my distributer cap getting some moisture in it and causing spark to disappear.
That was with my 1.4 still in, now with a 2.0 installed and a brand new distributer(it should be sealed better agains moisture) it happened again. Stopped, opened it up to find it completely dry...
Continued driving, its fine amd then its not fine...
Eventually later the day after it dying(no spark from coil) it started again... And then died for good with no spark from coil when turning it over, only 1 spark when ignition on.
Couldn't be the coil... No crank sensor...
Ivestigated wiring. Found the relay, under my cubbyhold, powering the dictator to be a bit moist. Dried it. Continued checking wiring. Saw a nice drop of water on the relay, WTF...(also no key in ignition, dicktator green light was on-not normal) took it out and shook it. Yes, filled with water. Yes ! Found the problem... No ! Dried it, put it back in. No green light anymore, good. Red light with ignition on. No green flickering(should show pulse) when turning over ! Dammit ! Didn't think it's the distributer at the time cause it's new ! Eventually took the dicktator out and found a diode disintegrated(burned away due to water causing short circuit) on the pc board. Replaced it, tried again. Still no pulse, no green light. Only culprit left, distributer ! Unplugged it, bridged it out to see if I get a spark.. Yes ! Spark !
Turns out it was the hall sensor that has also blown due to the short circuit of the relay.
Bought a new distributer and bob's your uncle !
Issue was water running down the wires from the engine bay down into the cab and into the relay, since it was just hanging there and wasn't suspended or fastened.
Problem was.
2008 VW CitiROX 2.0i (ADY)+(FFZ), Viper SS Free-Flow & Branches, Gas-Flowed Head, 288 *** CAM, Dictator STD.
2016 VW Scirocco R 2.0 TSI.
2020 Vrrrrrrr-Pah.
2020 Vrrrrrrr-Pah.
Good day everyone, my car is a vw mk1 with a 2.0l 8valve engine with ffz 1.4 gearbox,when I try to install a 2.0l flywheel and clutch kit my starter touches the flywheel upon every start up...how come? Thank you.
