Car not reving up
- Car Make: Mazda
- Car Model: 6 MPS
- Membership No: 1796
Car not reving up
Hay all
Ok so my car has been standing for more than a month now and I want to get it sorted now.
The problem is that the car sounds like it is taking when swinging the starter but it does not rev up from there, I have checked and there is spark on all 4 cylinders and I take it there is fuel as it does sound like it wants to take.
The problem came about pretty weird aswell, It was running fine, then just standing ideling it suddenly started getting more and more unhappy until it died, it did start after that but did not rev up from idle, even with wide open throttel, pulled plug wires off one by one and put them back and only when I pulled cyl 4 it died.
Any inputs would help, please, And it is a gotech mini x that I am using.
-2011 Audi S3 Sportback
-2004 Ford Ranger 2500D
-2015 KTM 1290 Superduke
-2010 Triumph Street triple
-2008 KTM 690 Enduro
EX Rides:
- 1987 VW Citi Golf - RIP
- 1988 VW Fox
- 2009 NO Limit cg 125
- GoMoto Ballistic naked SI
- Suzuki DRZ400SM
- 2007 VW Polo 1.6 Comfortline
- 1991 MK2 Jetta CLI 20VT
- 2006 Audi A4 Avant S-Line
- 2013 Honda CBR1000RR - RIP
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2008 Suzuki GSX650F
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
- Colonel
- Membership No: 1041
Re: Car not reving up
are you getting spark on all for leads, fit a old working plug in there, swing motor and check.
also did you set timing, double check this, maybe the dizzy is not locked tight and moved abit.
- Car Make: Mazda
- Car Model: 6 MPS
yes getting spar on all 4 leads, and did adjust the timing to get the car to where it is now
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
- Colonel
on idle does it sound like its missing and running on 3 cylinders?
Are you sure the actual plug in the head is sparking and working and not a dud.
other thing it can be is fuel pressure on at the rail if its not a spark miss or even compression.
- CTi4Life
- Car Model: MK1 2DR 2L 16VT
- Membership No: 1412
Did you check your fuel rail, block of the return and see if the car starts. Had the same problem with my Velo. Apparently the fuel rails break on the inside. Not sure why.
CTi4Life
_______________________
Membership # - 1412
"If you cant race it or take it to bed, then it aint worth having....."
80 Golf 1 2DR 16VT
96 Jetta VR6
07 Velociti 1.4i
Ex: 95 Golf 3 GTi
Ex: 96 CTi
Ex: MK1 GTi
EX: Beetle 1600 Twinport
Ex: MK1 Jetta, 1.8i
Membership # - 1412
80 Golf 1 2DR 16VT
96 Jetta VR6
07 Velociti 1.4i
Ex: 95 Golf 3 GTi
Ex: 96 CTi
Ex: MK1 GTi
Ex: MK1 Jetta, 1.8i
- Car Make: Mazda
- Car Model: 6 MPS
Thanx man will give that try now
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
- Car Make: Mazda
- Car Model: 6 MPS
It doesn't idle at all, But will try to see what happens when I block the returnUDC wrote:on idle does it sound like its missing and running on 3 cylinders?
Another thing I forgot to mention was that this whole running fine to not idling happend over about 1 minute
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
- CTi4Life
Same here bro, mine cut of on the road. Just died within seconds
CTi4Life
Membership # - 1412
80 Golf 1 2DR 16VT
96 Jetta VR6
07 Velociti 1.4i
Ex: 95 Golf 3 GTi
Ex: 96 CTi
Ex: MK1 GTi
Ex: MK1 Jetta, 1.8i
Membership # - 1412
80 Golf 1 2DR 16VT
96 Jetta VR6
07 Velociti 1.4i
Ex: 95 Golf 3 GTi
Ex: 96 CTi
Ex: MK1 GTi
Ex: MK1 Jetta, 1.8i
- Car Model: Amarok V6
- Membership No: 664
I would look at the things stated above and when that still does not make a difftence have a look at replacing the fuel in the tank and make sure all the filters are clean.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Car Make: Mazda
- Car Model: 6 MPS
OK guys, so I hooked up the jumper cables to try the things mentioned above, swinged it just to see what happens before I changed anything and it took, tuned the timing a bit, and it even idled and reved up nicely, drove it 500m down the road, turned around and it just died again. When I block off the return You can hear the petrol pump stops so dont think that is good but will just try it like that tomorrow cause the battery was too drained to swing it properly, and then try and replace the petrol filter.
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
- Tdi jetta 4 ever
It sounds like your battery is causing all off that. Get it charged overnight properly or get a new battery.
Robin
robinwisse@gmail.com
- Car Model: Cti
- Membership No: 2095
Im not so mechanically minded...but would'nt the above mean that the pump could not be supplying enough fuel therefore the car is starving for fuel and not starting, idling etc?...You can hear the petrol pump stops...
- Car Make: Mazda
- Car Model: 6 MPS
No I what I meant with that is that the pressure is so high the pump stops working, so I will just check it quick before I burn my pump.Tashveer wrote:Im not so mechanically minded...but would'nt the above mean that the pump could not be supplying enough fuel therefore the car is starving for fuel and not starting, idling etc?...You can hear the petrol pump stops...
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
- amstel18
- Car Model: Tiguan Allspace
Sounds more to me like the fuel pump relay is poked
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Car Make: Mazda
- Car Model: 6 MPS
Ok guys just a quick update,
I redid all the wiring off the management after truing everything suggested, tried it again and same problem.
I then changed the plugs and it started on the first turn, Bought new plugs, put it in and idled fine, drove out the yard and started losing power again and same problem occurred, I think the over fueling from the 2.0 map might be killing the plugs, what do you think?
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
- amstel18
post a pic of the plugs
Fuel shouldn' foul plugs that quickly. you sure its not oil? do a compression test
- Colonel
check fuel pressure, maybe rail is cracked
- Car Make: Mazda
- Car Model: 6 MPS
I havent removed the new plugs yet but will do that tomorrow evening when I get back from work and take a pick to post.amstel18 wrote:post a pic of the plugs
Will also try a comp test, just need to get my friend to bring his tester, but don't think it is that as the motor was running fine and did no fool around there when I did the gaskets.
If only I could get my laptop to work on the gotech I could load another map and see, but if all goes well will be taking the car for a tune on thursday
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
EX Rides:
- 1988 VW Fox
- Suzuki DRZ400SM
-2007 CBR 1000RR
-2007 Mazda 6 MPS
-2007 BMW 335i
-2011 Golf 6 GTI
I have problem with my car polo tdi 1.9 my car can start but is not reving and know power than cat of can you help me please
I am having the same problem on a golf 5 fsi..car starts and idles but doesn't rev..did you get any solutions?Gangire wrote: ↑Fri Feb 02, 2018 4:49 pm I have problem with my car polo tdi 1.9 my car can start but is not reving and know power than cat of can you help me please
- kmg4real
- Car Make: Volkswagen; BMW
- Car Model: CITI 2.0 16VT; E36 323i
- Membership No: 1381
I had a similar issue in my citi, in my case it was the water temp sender. Changed it to a VW original and life came back.
'02 CITI Golf 2l 16VT 243hp 306Nm @0.8 bar on M.R.D. Dyno - Thread url=http://www.vwclub.co.za/forum/viewtopic ... BlaqSmithe
'98 BMW 323i
Ex - '98 Polo Playa 1.6i
Ex - '11 BMW 320d
Ex - '08 BMW 320i Facelift
Ex - '07 Citroen C2 iPlay
Ex - '07 Golf V GTI
Ex - '04 Audi 1.9TDi 6 spd
Ex - '02 CITI Golf 1.4i
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
FACT: "I use not only the brains I have, but all that I can Borrow." - Einstein
