TDI Crank
GolfII GTi King
Car Model: MK4 Jetta 2.0
TDI Crank
Post by GolfII GTi King »
Can a 'boxed' TDI crank work on a 2.0 short block?
I know it is used on the 2.0 long block.
Membership number: 1115
Jetta 4 2.0
MK1 GT 2.0 16v
Golf 2 2.0 16v ABF Gotech
Golf 2 2.0 8v MP9 Unichip
carbonsport
Re: TDI Crank
Post by carbonsport »
cant do much on diesel engines :(
Digit Riaan
Registered for: 18 years 9 months
Re: TDI Crank
Post by Digit Riaan »
I'm not sure what a boxed crank is...but AFAIK you will need a bubble block for it to work. Also, the rods are short, so the rod ratio will be ****...
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100, '79 Golf LS
Torker
Car Model: Golf GT
Membership No: 1464
Re: TDI Crank
Post by Torker »
You have to mod a short block to get a 2.0 crank to swing, I don't think a TDi crank is gonna work in there, you will need a tall block.
Boxed and knife edged crank:
Current rides:
Hyundai - 1.4 Getz (daily)
Digit Riaan
Re: TDI Crank
Torker wrote:You have to mod a short block to get a 2.0 crank to swing, I don't think a TDi crank is gonna work in there, you will need a tall block.
Thanks, now I remember.
vwpro
Car Make: Audi Quatro, polo Beast and A3
Car Model: S3, Polo Playa,
Re: TDI Crank
Post by vwpro »
it can work,only in a 2,0L bubble block,stroke is 95,5mm, can even stroke it to 100mm and rebalance the crank after machining,but 100mm woundn`t work will touch the sleeve on the bottom edge, I think the big end gernal size is bigger on some tdi cranks, which you have to get down to the standard 8v petrol motor rods big end size,have to send for destress and niteride,and also do a mod to remove the oilpump gear,machined down the nose for the crank pully to fit and take standard crank pully
:troll:
graham savage
Registered for: 18 years 5 months
Car Model: Caddy's, Mk2's, Mk4, Ford etc
Membership No: 803
Re: TDI Crank
Post by graham savage »
Does anyone know if I can put this into a APK block??? :grin: :grin:
GolfII GTi King
Re: TDI Crank
Thanks for the replies.
I have done the 1.8 8v to 2.0 8v before.
82.5 pistons.
2.0 crank and machine the lip by the oil pump and a little off the intermediate shaft gear.
I see guys making 2.1 motors with the TDI crank and so I also want to do it.
But I only have a spare 1.8 16v short block motor atm.
Jetta 4 2.0
MK1 GT 2.0 16v
vwpro
Re: TDI Crank
Post by vwpro »
no that woudn`t work, not inought space for the crank to turn, conrod will fell the side of the block
:troll:
GolfII GTi King
Re: TDI Crank
Cheers.
So:
2e block
2.0 16v pistons with rods (or TDI rods?).
Modded TDI crank
16v intermediate shaft etc.
KR 16v head.
Jetta 4 2.0
MK1 GT 2.0 16v
Nolz007
Registered for: 13 years 2 months
Re: TDI Crank
Post by Nolz007 »
What is a bubble block? And will the tdi crank work in a 2e motor? I know it works in the abf
Torker
Car Model: Golf GT
Membership No: 1464
Re: TDI Crank
Post by Torker »
Nolz007 wrote:What is a bubble block? And will the tdi crank work in a 2e motor? I know it works in the abf
2E /ADY are bubble blocks, the TDi crank will work in a 2E motor. I've got one in an ADY block with 83.5mm pistons.
Current rides:
vwpro
Re: TDI Crank
Post by vwpro »
GolfII GTi King wrote:Cheers.
So:
2e block
Modded TDI crank
KR 16v head.
if use a long block 2e you have to use the rods aswell, tdi rods are to short
:troll:
GolfII GTi King
Re: TDI Crank
Cool!
Shopping list:
2e, ADY block
2.0 16v pistions + rods.
TDI crank
This going to take awhile.
Jetta 4 2.0
MK1 GT 2.0 16v
Wit Ark
Car Model: Citi Chico baby dragster
Re: TDI Crank
Post by Wit Ark »
Sorry for :hijack:
But if i intend to get a tdi crank for my 2.0 longblock ady, do i need to get 16v pistons as well? What will happen to my compression ratio? Is it a streight foreward swap? I take it the tdi crank is from a 1.9tdi motor?
maranou
Registered for: 15 years 5 months
Re: TDI Crank
Post by maranou »
Jetta 4 81kw Tdi 95.5mm give 2l 92.8mm 2.7mm more stoke so 1.35mm higher out the block so use 2e/ady/aba/agg/abf rods and block and get 20mm small ends and 9a/aal short block pistons so it sits flush with block and cr ok,to get 10 remove thick shim on stealgasket and use 3 left thin shims,or use nissan 1.8dej turbo pistons 83 and 83.5mm already got 21mm gutsinpins.
The 96kw crank has bigger bigend journals,no u got to grind it ofsenter to get 100mm but now u leave it for a day too cool of afterward and pull skew,now u recut it afterwards again hey.
To cut nose R550 to nife R650 to box R450 to balance total asemble that's a must R550 so u need a tdi crank say a 1.9tdi one that goes for R2000 and then spend R2200 on it to get it boxed and all so R4200 for a crank is abit high hey? And what about cutting a bigyournal smaller???
Golf 2l16vT 320kw 520nm
1/4mile @ 12.2 kilarney 2011
800m @ 233km/h
MK2 G60
Membership No: 388
Re: TDI Crank
Post by MK2 G60 »
The cranck will work.
We just finished one using a KR block with 84mm pistons from BMW.
There is a few things ones got to watch but it works really well.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
turbo srs
Re: TDI Crank
Post by turbo srs »
Lol thats still a easy mod. Im busy now with a motor, 1.9 tdi block, 1.9 tdi crank, ferrari titanium rods, forged pistons, 20v head, own custom built turbo with tdi 6 speed gearbox. Its puzzeling us but we getting there and aim 4 bug HP and good times on 400 m. :grin:
citi87
Registered for: 9 years 11 months
Re: TDI Crank
Post by citi87 »
What's the reason for boxing the crank?
Donavan
Re: TDI Crank
Post by Donavan »
9a is also bubble block.
95.5 will fit in a 9a block. There is some clearance issues that has to be adressed.
It has been done before.
Do a search on vortex there are plenty of them.
Audi A4 B8 2.0T - Daily
LoW n SloW
Re: TDI Crank
Post by LoW n SloW »
carbonsport wrote:cant do much on diesel engines :(
:lol: :lol: :lol: :lol:
maranou wrote:Jetta 4 81kw Tdi 95.5mm give 2l 92.8mm 2.7mm more stoke so 1.35mm higher out the block so use 2e/ady/aba/agg/abf rods and block and get 20mm small ends and 9a/aal short block pistons so it sits flush with block and cr ok,to get 10 remove thick shim on stealgasket and use 3 left thin shims,or use nissan 1.8dej turbo pistons 83 and 83.5mm already got 21mm gutsinpins.
interesting info
2001 'rolla 160 gle (ex)
2005 old schooled caddy (ex)
1995 vw golf 1 ((ex)
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Re: TDI Crank
Post by Unobeat »
Wow, we learn everytime. ..
Thanks for sharing guys the info...
sent from my Umsotho GT using Tapatalk
berry
Registered for: 9 years 1 month
Car Model: mk1 16V
Re: TDI Crank
Post by berry »
What size mains and big ends do i use with normal 1800 conrods?
Ashveer03
Re: TDI Crank
Post by Ashveer03 »
berry wrote:What size mains and big ends do i use with normal 1800 conrods?
Take ur crank to an engineer and ask them to measure it. They will tell u
berry
Car Model: mk1 16V
Re: TDI Crank
Post by berry »
Ashveer03 wrote: Sat Feb 09, 2019 11:27 pm
Ok tnx.. Coz currently i have standard 2L mains and big ends and was wondering if it will work as the tdi crank is also standard..
