mp 9 wiring diagram please
Re: mp 9 wiring diagram please
It really doesn't matter. As long as you get a resistance that goes from high to low for the full range of movement of the throttle. That will convert the 5v you put into it into a voltage that goes from low to high.
Hi All.
My trottle bodies for my MP9 -1600I is just not holding revs, cold start is a nigthmare and revs dont stay consistent. I it revs all the way 4000rpm at times and time the butterfly get stuck. I have to disconnect the trottel body from the computer box. Can some one please help or recommend a good engine management system.
- Colonel
- Membership No: 1041
rather change the Throttle body, from the description above its the root of all your problem....does the throttle body idle motor buzz and move slightly when you turn the ignition on, if not then the TB is toast....rather change that instead of changing the entire engine managementSHAUN9165 wrote: ↑Wed Jun 10, 2020 8:17 pm Hi All.
