Another ABF Build (NOW ON PERFECT POWER)
Re: Another ABF Build
u R 1 futtup stoopid **** rn't u
anyway..i do not have time for all this thanx guys i would not reply from now on
Yeay !!!!
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
Hey, Im young enough to understand some phone lingo but I still cant make out what on earth he has tried to say! Please talk sense else no one here is going to take you seriously!
and
and
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
2007 Audi S3
EX
Hi Ho Hi Ho
Back to Twincam forum he goes
I humbly beg for you forgiveness - it was me that went off topic but there is NOTHING on this earth that irritates me more than that kind of thing. It just proves to me that people in general are becoming less intelligent with time where I always thought it should be the other way around. If you cannot express yourself properly then you are no better than some animals.
- CRASH_IT
- Car Model: 8P S3
No worries.panic-mechanic wrote:I humbly beg for you forgiveness - it was me that went off topic but there is NOTHING on this earth that irritates me more than that kind of thing. It just proves to me that people in general are becoming less intelligent with time where I always thought it should be the other way around. If you cannot express yourself properly then you are no better than some animals.
Dont worry I sat here staring at the screen for some time trying to make out wat the hell he was trying to say. gave up eventually! lol
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- CRASH_IT
- Car Model: 8P S3
@ Panic: With the PP management system, I think I will run my ABF on the std 60-2 for now then fit the wasted spark from the G4 like you advised. What magnetic pick up do I need to get that will fit in my block? my std ABF dizzy and cap is still 100%.
Also can I use my current MP9 coil on this set up?
I am just trying to put together my shopping list of what I need.
Do you advise me to run a lambda?
I want to run safely and economically as possible.
thanks
thanks
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
There is an Opel pickup - available from GW that is the same length that fits. Take the current pickup out and take it to GW for a length comparison. Be carefull when you fit it. It has to go in flush - you remove the little plastic ring that it comes with otherwise it will stand proud of the block an crack the mounting point - it also won't read the trigger wheel then.
YES I strongly suggest running the Lambda - that is where all the niceties come from. Without it it's just any other old management.
Yes you can use the current MP9 coil and Either buy a blue fire now already as a coil amp and then you are ready when you go wasted spark or you can use a single Tp1000 which is a positive trigger TCI out of a bantam to fire your single coil for the moment and later get another or buy a blue fire then. TP1000 = +- R220 - must be Echlin brand.
Blue fire - R1000.
Blue fire - R1000.
- SHAUN
- Post Whore
- Car Make: BMW
- Car Model: 2006 335i
- Membership No: 1148
If you are planning on running the 60-2, then why do you want to run the dizzy, just go wasted spark onetime.CRASH_IT wrote:@ Panic: With the PP management system, I think I will run my ABF on the std 60-2 for now then fit the wasted spark from the G4 like you advised. What magnetic pick up do I need to get that will fit in my block? my std ABF dizzy and cap is still 100%.
For the crank sensor you can use the opel 2L 16v sensor, they are R550 from goldwagen.
As for the coilpack im running the opel corsa one.
Then all you need is the perfect power bluefire ignition amplifier for the coilpack.
The STD ABF dizzy is a 1 window dizzy, you will need the 4 window dizzy anyways. Or modify the ABF one.
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
If you run 60-2 pickup you can still happily fire the dissy and it needs no mods to the pickup as you won't even be connecting it. Unless of course you want full sequential fuelling in which case you will use the pickup - as is with it's 1 trigger window. But it really does very little for economy - which can still be achieved without having to go full sequential.
- CRASH_IT
- Car Model: 8P S3
Ok cool So I can keep my dizzy u saying,
what I will need is (just correct me anything I'm missing) for managment:
1.A magnetic pick up.
2. Blue fire coil amp
3. lambda
4. PP xms4B 4A
Were does the PP get it's MAP from? Does it have it's own MAP sensor?
Thanks guys
3. lambda
4. PP xms4B 4A
Thanks guys
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
XMS4B-4A has it on-board, yes. The XMS4B-4 doesn't.CRASH_IT wrote:Were does the PP get it's MAP from? Does it have it's own MAP sensor?
- Major-General
- Registered for: 21 years 2 months
- Car Model: MK1
WANT2PLAY wrote:my abf killz the e36 e42 e96....bt nw i will murder dem...am talkn train gapz nw
LOL! Where did that come from? One minute I'm reading about MP9 Vs AM, next this statement pops up outta the blue...
Train gapz...... freight trains or pasesnger ???
Rofl...
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
- Solo786
- Car Make: Porsche,BMW,VW
- Membership No: 1251
surely you mean "e46 and e92"WANT2PLAY wrote:my abf killz the e36 e42 e96....bt nw i will murder dem...am talkn train gapz nw
i lol'd at this
- rydogg
Don't even go there...Solo786 wrote:surely you mean "e46 and e92"WANT2PLAY wrote:my abf killz the e36 e42 e96....bt nw i will murder dem...am talkn train gapz nw
i lol'd at this
......___
..../|_|_\__.......= _|_\__
..|@_|_|@|......|@_|_|@|
Mk1 cabriolet - old schooled!
- Car Model: Cti
- Membership No: 2095
This sort of attitude will take you faaaaaaaaaaaaaaaaar in life bud. Goodluck!WANT2PLAY wrote:.....HAHAHA WHAT KUNTZ..
- SHAUN
- Post Whore
- Car Make: BMW
He says e36 e42 e96's.....must be talking bout 320i'sSolo786 wrote:surely you mean "e46 and e92"WANT2PLAY wrote:my abf killz the e36 e42 e96....bt nw i will murder dem...am talkn train gapz nw
i lol'd at this
- CRASH_IT
- Car Model: 8P S3
Re: Another ABF Build getting completed
So Im ready to drop the motor in this weekend.
Cant Wait picking up my last parts I need today: a TNT Branch, brake bottle and plugs!
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- Registered for: 20 years 3 months
- Car Model: Amarok V6
- Membership No: 664
My magtig... Look who's alive still !!Zubair wrote: LOL! Where did that come from? One minute I'm reading about MP9 Vs AM, next this statement pops up outta the blue...
Rofl...
Hello buddy long time no see
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
Please tell me that TNT now has these branches available off-the-shelf? I mean, for a long-block 16V in a mk1?CRASH_IT wrote:Cant Wait picking up my last parts I need today: a TNT Branch
Mind if I ask how much it is? Can PM if you prefer.
- pluto
- Registered for: 20 years 6 months
Re: Another ABF Build (update)
Yup .. off the shelf - R1800 IIRC
Shiver me Wastegates
Frieling Racing Chip tuning
Yashin@frc.co.za
082 805 9060
2013 TT-RS S Tronic
MK1 20VT BAM (Motronic ME 7.5 DBW)
Yashin@frc.co.za
082 805 9060
2013 TT-RS S Tronic
That is GREAT news. Really didn't feel like sending the car there for a few days.pluto wrote:Yup .. off the shelf - R1800 IIRC
OUCH on the price though. Last time I bought a branch there, it was R800. Granted, this was about 10 years ago.
bought mine for R1100 begining of the year.
4-2-1 though, they didnt have the 4-1 off the shelf for the long block
BMW k1200RS
You still have it? Seeing as I'm using your pistons....Monster wrote:bought mine for R1100 begining of the year.
