What are the signs of bad inner cv joints on a Jetta 2.
I know what bad outers sound like, but not sure how to diagnose inners.
My car makes a clucking noise when i accelerate.
- Car Make: Jetta 3 CLX
- Car Model: 1996
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Re: signs of bad inner cv joints
My Velo had an inter clicking noise when driving in a straight line, you could feel it on the steering as well. I assumed it was caused by a partially seized inner CV and the fact that it went away after I changed the CV's confirmed it.
Current rides:
Hyundai - 1.4 Getz (daily)
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
I had one stuffed inner CV joint. The symptoms I experienced were similar to having very bad wheel balancing. Apparently, the heat from my gearbox/exhaust caused the grease in my inner CV to become hard... When driving on a highway it would feel as if my wheel balancing was way out. I could "cure" this by turning very sharply from side-to-side (going slowly of course). But it would emerge again. It also seemed to get worse when I was driving long distances (e.g. more than 100km non-stop).
Cheers>
Cheers>
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Car Model: 1996
Thanks guys. Will rather book my car into a suspension place to have it checked out.
- Scatman
- General
- Car Make: BMW
Jup, thats the best thing to do. If its something else, then they'll pick it up. Hope you get it sorted budDealer_1 wrote:Thanks guys. Will rather book my car into a suspension place to have it checked out.
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Post Whore
- Car Model: boat
- Membership No: 1133
+1Torker wrote:My Velo had an inter clicking noise when driving in a straight line, you could feel it on the steering as well. I assumed it was caused by a partially seized inner CV and the fact that it went away after I changed the CV's confirmed it.
i had both sides inner and outer done at the same time just to make sure it wouldnt trouble again
- Car Make: VW & SEAT
I found that on my car, when I took those looping onramps and accelerated in the bend, I would get a clicking noise, and tthe noise would disappear if I lifted off the throttle. Changed the inner CV and problem solved.
- Car Model: Polo 1.9tdi
Hey Scatman,Scatman wrote:I had one stuffed inner CV joint. The symptoms I experienced were similar to having very bad wheel balancing. Apparently, the heat from my gearbox/exhaust caused the grease in my inner CV to become hard... When driving on a highway it would feel as if my wheel balancing was way out. I could "cure" this by turning very sharply from side-to-side (going slowly of course). But it would emerge again. It also seemed to get worse when I was driving long distances (e.g. more than 100km non-stop).
Cheers>
I think I have the same problem as the one you described above. My discs keep shuddering, so I replaced my hubs (I think they added to the problem). But now I still have vibration above 100km/h. Last week I did balancing, but still shuddering. I took my car to a Driveshaft & CV shop and they said there is play on both my inner CVs. It is driving me mad!
How did you resolve the problem?
Did you replace them, or just a service?
Did that resolve you vibration problem?
Gerrit
- Scatman
- General
- Car Make: BMW
Hi GerritGJHuman wrote:Hey Scatman,Scatman wrote:I had one stuffed inner CV joint. The symptoms I experienced were similar to having very bad wheel balancing. Apparently, the heat from my gearbox/exhaust caused the grease in my inner CV to become hard... When driving on a highway it would feel as if my wheel balancing was way out. I could "cure" this by turning very sharply from side-to-side (going slowly of course). But it would emerge again. It also seemed to get worse when I was driving long distances (e.g. more than 100km non-stop).
Cheers>
Gerrit
Yes I just replaced all my CV joints and the problem was solved. I bought "Solid" CV joints amd they were pretty much identical to the OEM ones I had on my car, even the grooves from the machining process were exactly the same.
The car was a pleasure to drive after fitting the new CV's, the original CV's lasted 220 000km.
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
