DQ200 Gearbox
DQ200 Gearbox
Hi Guys,
I took my audi in to 4Stroke Auto CLinic in november for a new clutch.
Long story short we have laid criminal charges against the owner....
My question.
what exactly sits here on the gearbox?
Something broke off but i have no idea what.
is this going to end up being a replace the gearbox scenario?
My question.
- mk2-phreak
Re: DQ200 Gearbox
I'm sure you meant clutch packs, since you have a DSG box.
Yeah you're gonna have to get a replacement box
Re: DQ200 Gearbox
Yeah the dual clutch pack.mk2-phreak wrote: ↑Sat Jun 11, 2022 1:40 pm I'm sure you meant clutch packs, since you have a DSG box.
Eish new gearbox, ideas where i can get one for a good price?
- Membership No: 2033
Re: DQ200 Gearbox
Looks like it is some sort of vent / cover (see Black plastic thing in pics below) 2nd top pic, next to bar code sticker. From your pics your can see it is a casting hole with part of the wall broken off....
Click to inlarge
https://stringfixer.com/files/251530572.jpg
Click to inlarge
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- dcmk4
- Car Model: MK7 GTi
Re: DQ200 Gearbox
It just looks like they cracked a piece off the casing from the inspection hole, not a big deal.
There's just a plug that covers it usually like in the pictures above.
They probably put some sort of tool or bar in there to try lock the flywheel or loosen a bolt and broke a piece off the housing.
DQ200 is dry clutch and the bellhousing has no fluid in that area so nothing would leak per say.
A plug to cover the hole and you're good to go.
- Membership No: 3103
Re: DQ200 Gearbox
That should be a relief to the owner. Thanx for claritydcmk4 wrote: ↑Sun Jun 12, 2022 2:52 pm It just looks like they cracked a piece off the casing from the inspection hole, not a big deal.
'09 8P S3 Sportback (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
Re: DQ200 Gearbox
Thats a huge relief.dcmk4 wrote: ↑Sun Jun 12, 2022 2:52 pm It just looks like they cracked a piece off the casing from the inspection hole, not a big deal.
Thanks guys.
- Registered for: 4 years 4 months
Re: DQ200 Gearbox
Hi guys. Where did you buy your clutch? I recently bought a 2015 Jetta 1.6 TDI DSG 7 speed (DQ200, I think) and need to replace the flywheel and clutch.
Re: DQ200 Gearbox
At goldwagen. However, they needed to phone LUK with the vin number to get the part number. On their system the clutch was listed under polo 1.4 DSG.
Cost just over 8k
Re: DQ200 Gearbox
Thanks man
