Golf Mk1 overheating
buttle
Registered for: 9 years 11 months
Car Model: Mk1 Golf 1.4i
Post by buttle »
Can someone please give me a checklist of things to look out for an overheating problem.
I recently replaced the front manifold temp sensor and the actual plastic manifold that is fits into (there was a small pinhole leak in the side)
The water level is correct but after driving for about 15 or 20 mins... the Temp dial goes to max and the oil and temp warning lights come on.
Could the wax motor thermostat be dead?
Are there any other sensors that need checking?
Do I need to flush the radiator?
It used to run perfectly well for sooo long!!! and now this out of the blue :bang:
TIA
Kindest regards
Peter Butler
Mk1 Golf 1.4i
Mk12009
Registered for: 4 years 2 months
Car Model: Mk1
Re: Golf Mk1 overheating
Post by Mk12009 »
The temp sensor does exactly what it says which is sensing a temperature change and the fact that it gradually goes to max on the cluster means it is sensing and i doubt the issue is there.
1. First thing to check does the radiator fan kick in - it should within 10 minutes while car is idling - probably the sensor area, fan or fuse
2. If the radiator fan kicks in then
2.1
I would suspect that the thermostat is stuck closed and not letting cooled coolant to the engine
2.2 clogging somewhere in the coolant system
Check out this video for further details
https://youtu.be/iLaJAbmAuPg
Sent from earth
VAG Fan
Post by VAG Fan »
Peter, did you bleed the air from the system?
Gavan
Registered for: 3 years 7 months
Post by Gavan »
Please check that the top 8mm pipe that goes to the water bottle is open on the radiator, sounds like air is trapped in the radiator
Sent from my SM-G988B using Tapatalk
