I'm having an issue where vagcom won't read the ECU unless the engine is running . This is a problem as I need to do a throttle body alignment but can't do so as the ignition needs to be turned on but engine off to do this . I suspect some sort of wiring issue is causing this . Any idea where I can start looking ?
The other modules can be read by vagcom with just the ignition on , only the ecu is a problem . I did try removing the aftermarket radio and connecting the vagcom but this didn't help .
Car is a golf 4 gti 1999 (AGU). Thanks in advance for the help .
Golf 4 VCDS issues
- Car Model: Mk4 GTi (110kw)
- Registered for: 9 months
- Car Model: Mk3
Hydraulic lifters
Good evening all
Just want to know what hurts hydraulic lifters because I'm on my second set of hydraulic lifters the mechanic say it's my valves are hurting them so I bought a second hand complete head instilled the head and still the noise is there I got a new oil pump in I'm lost and losing my mind to this problem need some advice
