Howsit Guys
Reaching out to find out if anyone else ever had this issue on a VW Golf 7 GTi 2015
|Symptoms are random ,They could appear today and not tomorrow
- Power Steering gets heavy
-Start Stop Error
-Radiator Fan kicks in full blast ( The car could be ice cold at times)
Battery was tested and changed (19/03/2021)
Alternator to Body Ground Cable with Sensor was changed Twice
No lights on the dash
Car was scanned while fault was happening and we manged to get this code
Address 19: CAN Gateway Labels: 5Q0-907-530-V1.clb
Control Module Part Number: 5Q0 907 530 AC HW: 5Q0 907 530 F
Component and/or Version: GW MQB High 128 1204
Software Coding: 030100042F085900EF00026A1C0F00010001050000000000000000000000
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_GatewLear 011020 (VW37)
ROD: EV_GatewLear_011.rod
VCID: 72BC24F8B429F0FBA15-8026
1 Fault Found:
8521278 - Battery terminal recognition
U1411 00 [009] - Open circuit
[Spannung Fahrbatterie mechanischer Fehler]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 166
Mileage: 173216 km
Date: 2022.02.02
Time: 14:32:21
Terminal 30 power supply: 14.4 V
Terminal 15: On
Wednesday,02,February,2022,15:01:08:27926
VCDS Version: Release 21.9.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.clb
Control Module Part Number: 3Q0 907 379 F HW: 3Q0 907 379 F
Component and/or Version: ESC H42 0609
Software Coding: 01FA93A13429297407800606C1C4A980C92C94E0608395F700420038C209
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027 (VW37)
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 3D26C7C4BDF77F838C7-8068
3 Faults Found:
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 203
Mileage: 173130 km
Date: 2022.02.01
Time: 00:08:35
VW Golf 7 GTI Heavy Steering, Start Stop Error ,Radiator Fan
- Car Make: Vw, Bmw, Merc
- Car Model: 81 Vw Mk1 Cabrio,15 Mk7GTi
- Membership No: 3258
- Car Model: Mk2 GTS
Re: VW Golf 7 GTI Heavy Steering, Start Stop Error ,Radiator Fan
Hi, Fan running might be a wear on your temperature sender unit. Power steering heavy issue might be a warning for your steering rack or its module or an earth problem somewhere. Thanks
S4 2004 --> Stock
A3 2010 1.8T Cabrio --> Stock
Previous
Golf Citi 2.0 8v MP9 2007
Jetta 4 V5 10V
Honda CB400 '74
S4 2004 --> Stock
Previous
Jetta 4 V5 10V
Honda CB400 '74
