Hey good day guys I'm driving a polo 6r tsi 2015
my heat Guage are fluctuating from 90 degrees to 130 degrees it happend just suddenly after I came from the shop park ND checked car everything seems fine no signs of overheating nothing
Checked now heat gauge does still the same thing but still no signs of overheat all pipes or hot both bottom ND top rad pipe
Anyone experienced this before please help the gauge making me mad thanks in advance
Heat gauge fluctuating from 90 to 130 degrees and back
- Car Model: Polo 1.2 TSI
Re: Heat gauge fluctuating from 90 to 130 degrees and back
How fast is the fluctuations?
Get a diagnostic tool on it and check readings of sensors. There should be a coolant sensor on the radiator and one on the block. They should both read similar readings off by 1 or 2 degrees if the engine is warm.
Hi callum229
I've got vcds plugged in scanned the car and I got two faults 1st one was coolant pump for intercooler mechanical malfunction
The second one was the coolant temperature sensor the problem I have is I can't locate where the coolant temp sensor is on the block. My radiator fan goes on like normal everything works properly.
Which means the switch on the radiator works perfect.
Just a update Gents my issue about the heat gauge fluctuating it's sorted
The problem was the temperature switch at the back of the engine block I did clean it and all was well again
Thanks a lot for your response.
