1.8 T ( AGU) better sump option and headbolt size
- Car Model: Mk4 GTi (110kw)
I recently had to rebuild my engine as I broke the sump on a not so well marked speed bump . I drove for a bit after as it wasn't safe to stop at the time . I've got everything back from the engineers and the engine build will begin soon. Just wondering if there's a stronger sump or perhaps a shallower one for these engines available ? If so where can I find them in or around the durban area? Also ,what is the correct spline to use on the headbolts for these engines ? To remove them I had to tap in a hex t55 , the Victor reinz replacement headbolts have the same pattern . I don't want to damage the new bolts when torquing the head down .
Re: 1.8 T ( AGU) better sump option and headbolt size
The strongest sump to use would be an original. Aftermarket sumps, from goldwagen seem to be much weaker than the stock one.
The head bolt don't use a normal torx t55, I think the one u need is called a ribe socket, to be honest I don't know exactly what it's called. Lol.
The edges on it are different from torx
Contact Quality tools and fasteners, they based in overport. If u go there with the bolt he should have the tool u need. He's a a king Tony dealer
- Car Make: SEAT
- Membership No: 478
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Car Model: mk2 Jetta
Just take a headbolt to autozone and get the tool for that
