Hi just a small question i have a 2.1l 2E 8v motor with an mp9 comp but want to go to a 16v head with a turbo,I know i will need to get an after market efi and that is no prop but my biggest headache is the part list for the 16v head.I will get a complete head with the manifolds and cams and new bolts with the distributor but what else is needed:
1: Will the 16v crank pulley work my other pulleys currently on
2: Will the 16v inter shaft fit with the 2.1l conversion ( crank turning space )
3: will a 16v oil pulley fit my inter shaft with my old oil pump and dizzy
4: what cambelt will i use with this conversion
2E block with 16v head parts list
- Registered for: 4 years 5 months
- Car Model: MK2 GTI
VW MK2 GTI golf
ABF BLOCK
HEAD REDONE MAX
CARAVELLE PISTONS
CAM
ABF BLOCK
HEAD REDONE MAX
CARAVELLE PISTONS
CAM
