Golf 6 gti 2010
- Registered for: 12 years 3 months
Golf 6 gti 2010
Sup gents ,
Been a while.
Just a quick one or two
Does the 2010 model come with auto headlights?
I seem to be having an issue with my dashboard control unit as the lights are on continously even in off position.
2ndly ,
What can I do fix the number plate error message on dashboard as I have installed the leds and at that moment an error message appeared on dashboard.
Thanks in advance guys
Sent from my SM-G960F using Tapatalk
Been a while.
2ndly ,
Current :
2008 1.9tdi 6 speed 4door
2022 Toyota Corolla Xr
- Zie_Khumz
- Registered for: 9 years 5 months
Re: Golf 6 gti 2010
Does your LEDs have an error cancelation fixture
Sent from my SM-A715F using Tapatalk
Re: Golf 6 gti 2010
No bro, it doesn't.Zie_Khumz wrote:Does your LEDs have an error cancelation fixture
Where can I get that ?
And any idea about a 2010 gti having auto headlights ?
Current :
- Zie_Khumz
Re: Golf 6 gti 2010
Where are you based, I know places around durban.
Re: Golf 6 gti 2010
From durbs bro.Zie_Khumz wrote:Where are you based, I know places around durban.
Current :
- Zie_Khumz
Re: Golf 6 gti 2010
Try jabsport, has good prices as well
- Belix
- Car Model: Passat B8
Re: Golf 6 gti 2010
2010 Headlights act a DRL so always on, you can code them out using VCDS, or set something else as DRL. I swapped mine for the later LED DRL units and coded them to have normal auto functiondeon rupnarain wrote: ↑Thu Dec 03, 2020 2:10 pm Sup gents ,
Been a while.
2ndly ,
Re: Golf 6 gti 2010
Cool thanks will doZie_Khumz wrote:Try jabsport, has good prices as well
Current :
Re: Golf 6 gti 2010
Thank you for the advice ,Belix wrote:2010 Headlights act a DRL so always on, you can code them out using VCDS, or set something else as DRL. I swapped mine for the later LED DRL units and coded them to have normal auto functiondeon rupnarain wrote: ↑Thu Dec 03, 2020 2:10 pm Sup gents ,
Been a while.
2ndly ,
Just come from RS performance and Gershon recorded and its 100znow.
Thanks alot for directing me.
Current :
Re: Golf 6 gti 2010
This issue came back ?Belix wrote:2010 Headlights act a DRL so always on, you can code them out using VCDS, or set something else as DRL. I swapped mine for the later LED DRL units and coded them to have normal auto functiondeon rupnarain wrote: ↑Thu Dec 03, 2020 2:10 pm Sup gents ,
Been a while.
2ndly ,
Any reason why because when I left It was all good .
This mrng i started and it came back ....
Current :
