Golf 7 Gti dsg 2.0 White smoke
- Registered for: 4 years 9 months
- Car Model: MK7 GTI DSG
Hi All
Just need some advise,yesterday I was driving my Gti in sport mode. Next thing a huge puff (in high revs)of white smoke came out the exhausts. My initial thought was either turbo or inter cooler. After the incident, I drove on as normal and there is nothing wrong with the vehicle. Power is there and everything. I am stunned, any advise on what it might have been ?
- pyro-zn
- Car Model: Golf 7R
- Membership No: 2072
Re: Golf 7 Gti dsg 2.0 White smoke
I believe it's the PCV and happens from time to time (normal).hendriputter wrote: ↑Thu Jul 04, 2019 12:15 pm Hi All
Current: '17 Golf VII R
Ex: '12 TR Golf Vi GTi DSG ::: Revo3 - thread
Ex: '13 Polo 1.4 Comfortline ::: PanoRoof | JOM Bluelines | 17" A-Line Racers | 17" VW Boavista's by Borbet - thread
hi
What is the PCV ? So I don't have to stress to much about it ? Not very technical when it comes to these types of things,sorry
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
During the pull, as in while full throttle, or after you lifted off? Or during a shift? the EA888.3 motor is susceptible to oil-surge, but that's normally under track conditions. What happens is oil accumulates inside of the PCV/Front of the head instead of draining back to the sump, as you lift off, the oil moves forwards, and the vacuum in the manifold sucks it into the intake through the PCV = white smoke.hendriputter wrote: ↑Thu Jul 04, 2019 12:15 pm Hi All
Racingline takes care of this with their CC kit: https://www.racingline.com/vwr13g700
You shouldn't be seeing this on the road though, especially if not under braking. It could be a failed PCV as Pyro mentioned or it could be as a result of higher than normal sump pressure.
hi
It was actually as I approached a stop sign. So I was braking at the time.....
Thank You
Thank You
Hi Thanas
I am looking to buy an oil catch can for the wifes 7R.
I had the BMS occ on my old 335. So naturally I am looking at BMS again.
Would you say this Racingline can would be the one to get rather?
THANAS wrote: ↑Fri Jul 05, 2019 8:59 amDuring the pull, as in while full throttle, or after you lifted off? Or during a shift? the EA888.3 motor is susceptible to oil-surge, but that's normally under track conditions. What happens is oil accumulates inside of the PCV/Front of the head instead of draining back to the sump, as you lift off, the oil moves forwards, and the vacuum in the manifold sucks it into the intake through the PCV = white smoke.hendriputter wrote: ↑Thu Jul 04, 2019 12:15 pm Hi All
- THANAS
- Forum Advertiser
The stock PCV system is a pretty advanced and very functional design. If the car is not going to be seeing much higher than stock boost pressure or aggressive driving/track use, I would say that you don't need to install a catch can at all. The design of the stock PCV acts as a catch can of sorts with a returning oil-seperator etc.
The VWR catch can is a very neat package(albeit expensive) and looks/performs well , I can't say how it compares to other kits as I haven't had any experience with them.
hi Thanas
Stock
Stock
- Registered for: 6 months
Hi, I have the same problem from time to time under hard acceleration. New pcv valve, Installed a catch can with breather filter on top, reduced it but still happens. It starts under full throttle/high revs in sports mode and then as soon as I release accelerator, clouds of white smoke. I dont recall it ever happening in manual mode. Mk7r with EFR turbo. What else could it be? Any advise appreciated. No one could solve it yet and spent unnecessary along the way.
Thank you.
Thank you.
THANAS wrote: ↑Fri Jul 05, 2019 11:57 am The stock PCV system is a pretty advanced and very functional design. If the car is not going to be seeing much higher than stock boost pressure or aggressive driving/track use, I would say that you don't need to install a catch can at all. The design of the stock PCV acts as a catch can of sorts with a returning oil-seperator etc.
