Howsit guys,
I'm new to the forum. I would just like some advice on a 1.4 tsi Scirocco I recently bought.
The car has 120k kms on and just had a service from VW.
I noticed the the sound was coming from the high pressure fuel pump. The noise only comes through on idle.
I ran the diagnostic and it showed Low Fuel pressure. Has anyone else had this issue before? Is this a part that can be fixed?
Or must it be replaced. Would appreciate your thoughts on this.
Scirocco TSI_Fuel Pressure Pump Issue
- Arnu
- Car Model: Scirocco
Re: Scirocco TSI_Fuel Pressure Pump Issue
Replace only, no fixing. But make sure the isue is not from the low pressure side that starves the pump of fuel.
- Arnu
Okay cool, thanks man! Will look into that!
