Mk 7 gti performance drop in flat pad filter vs CAI kit comparison.
Hi guys,
Has anyone tried any of these two options or both as a comparison on which works better?
Doesnt make sense in buying expensive carbon to dolly up an engine bay but it does the same on performance as a flat pad filter.
- Car Model: Mk5 gti
Re: Mk 7 gti performance drop in flat pad filter vs CAI kit comparison.
Ive played around with cai and flat pads a few times on my mk5 gti...the flat pads are an upgrade to the standard filters coz the air flows through much easier and it's alot more silent than the CAI u won't get the flutter and sucking sound ...if ur after performance than a PROPER cai is definitely the way to go maf scaling is very important so make sure it's from a brand who actually takes the scaling into consideration when making them and make sure u have a heat shield coz the point of a cai is to suck cold air .also advantage on the cai is you get a nice sucking sound and also flutter when u tap the gas inbetween shifts and there are no restrictions in the pipes and bends
viewtopic.php?f=11&t=217296
Previous :too many to list
This is for a mk7, totally different setup.Trishen94 wrote: ↑Tue Apr 09, 2019 11:57 am Ive played around with cai and flat pads a few times on my mk5 gti...the flat pads are an upgrade to the standard filters coz the air flows through much easier and it's alot more silent than the CAI u won't get the flutter and sucking sound ...if ur after performance than a PROPER cai is definitely the way to go maf scaling is very important so make sure it's from a brand who actually takes the scaling into consideration when making them and make sure u have a heat shield coz the point of a cai is to suck cold air .also advantage on the cai is you get a nice sucking sound and also flutter when u tap the gas inbetween shifts and there are no restrictions in the pipes and bends
Lmao buddy ...even if it's a Ferrari same rules apply ...it must suck cold air not hot engine air , have proper maf scaling , as little bends and restrictions as possible
- Membership No: 2033
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Titleists
- Philosopher STIG
- Car Model: 2016 Golf R
- Membership No: 1520
I would also like to know. If someone has a panel filter and intake, let's do some runs with my VCDS and test it.
- Car Model: Golf MK7 R
Howzit Gents
I had the flat pad performance filter in my 7R, as I was the same in thinking why spend the money on the more expensive CAI. and I can't really say that it made a difference as you won't notice anything, but I am sure with proper logs it will pick it up.
But then I forked out the money for the VWR R600 intake and man o man, it is a difference you will notice straight away, the throttle response is better, power delivery is better and it makes all the right sounds.
I will spend the money on a proper CAI, as you will end up spending it in any case in the long run.
Current: 2014 Golf 7R
Previous: 2011 Audi A3 1.8TFSI - 211kW
Previous: 2005 Megane RS
My question is regarding a mk 7, not a Mk5. Thanks for advice on something I already know about a Mk 5. Ferrari, now thats a different class all together
Thanks Koena! Trishen94, this was the answer was looking for.Koena wrote: ↑Tue Apr 09, 2019 1:50 pm Howzit Gents
No fuss bud ...im glad u found the info u where looking for... give us feedback on it once u install
Shots fired......
HOWIE-WP,
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
Not entirely true, as the EA888.3 doesn't use a MAF, all VE calcs are achieved with PUT (Pressure Upstream Throttle)/MAP sensors. You can do pretty much whatever you want with the intake without worrying about the ECU being out of sync. One of the many benefits of the Simos18 ecu it uses. The original airbox already takes in cold air from the front collector, which is a lot larger than on the Mk5. So the coolness of air isn't the issue, the key with the Mk7 GTi is to get an intake that retains the collector but is shaped for smoother flow at the flow levels achieved on a tuned motor. The VWR intake has been proven to be an effective solution, albeit rather bland looking.
Learning alot everyday on the forum thanks for the explanation thanas I was unaware of that but atleast now I knowTHANAS wrote: ↑Wed Apr 10, 2019 8:35 amNot entirely true, as the EA888.3 doesn't use a MAF, all VE calcs are achieved with PUT (Pressure Upstream Throttle)/MAP sensors. You can do pretty much whatever you want with the intake without worrying about the ECU being out of sync. One of the many benefits of the Simos18 ecu it uses. The original airbox already takes in cold air from the front collector, which is a lot larger than on the Mk5. So the coolness of air isn't the issue, the key with the Mk7 GTi is to get an intake that retains the collector but is shaped for smoother flow at the flow levels achieved on a tuned motor. The VWR intake has been proven to be an effective solution, albeit rather bland looking.
- THANAS
- Forum Advertiser
No problem at all, here's one of my favourite intake manufacturer's offering for the Mk7/7.5 (probably costs infinite money, but still):
http://www.eventuri.net/products/vw-golf-mk7-gti/
Claiming around 25 Hp gain on a tuned motor.
- General
- Car Model: Golf 7R
Made a good difference on my car. Also has a nice induction sound and turbo sound. Fuel consumption is also lower with the intake on.
If you are going to do a drop in filter, change the intake pipe and 90deg bend TIP and also mod the intake vents - Stock the side of the intake is blocked - open up these vents. The TIP inlet pipes makes a nice difference on the IS38, not sure on the IS20.
Stock run vs intake and 90deg TIP
- General
This does look nice hey! Any idea on costs?THANAS wrote: ↑Wed Apr 10, 2019 1:14 pm No problem at all, here's one of my favourite intake manufacturer's offering for the Mk7/7.5 (probably costs infinite money, but still):
- Car Model: White-G5 GTi
Better Car breaths = Better Car Perform,..Right hardware upgrades is always a Plus!
Fitting proper Intake couple with DP will allow turbo spool up better, thus generating better performance.
Jis 2cent: Fitting a Intake will allow for better spool but will not do much for Cold Air intake as the Turbo will spool up the air temps anyway,..now that where Cooler makes difference (JIS 2cent there eks se) e
- General
Like the guys said, the MK7 is mafless. Also, have you felt the intake pipe after the car is driven? The air from the filter to the turbo is DEFINITELY going to heat up from the time it leaves the filter to the time it enters the turbo.
- General
LOL beat me to itCamo wrote: ↑Wed Apr 10, 2019 1:57 pm Better Car breaths = Better Car Perform,..Right hardware upgrades is always a Plus!
- General
all good bud,..will chat to you so, in process of getting a 7.:RHotdubz wrote: ↑Wed Apr 10, 2019 2:01 pmLOL beat me to itCamo wrote: ↑Wed Apr 10, 2019 1:57 pm Better Car breaths = Better Car Perform,..Right hardware upgrades is always a Plus!
- THANAS
- Forum Advertiser
Have the car tuned, then head to the dyno with your stock and CTS intakes, for science.
- General
Anytime dude. Just give me a shout.Camo wrote:all good bud,..will chat to you so, in process of getting a 7.:RHotdubz wrote: ↑Wed Apr 10, 2019 2:01 pmLOL beat me to itCamo wrote: ↑Wed Apr 10, 2019 1:57 pm Better Car breaths = Better Car Perform,..Right hardware upgrades is always a Plus!
- General
Definitely will and will share too.THANAS wrote:Have the car tuned, then head to the dyno with your stock and CTS intakes, for science.
