2008 Opel corsa opc 50 000km
Car is lacking power .turbo still boosting ...we are hearing a humming/Whistle noise very loud cannot find from where when car is under WOT ...
Actuator checked
Recirculation valve checked
Boost pipes checked
Turbo checked shaft still good
No engine light showing
No miss fire or anything...slight backfire as normal car when changing gears car is factory stock plz guys help us out
OPC HELP NEEDED URGENTLY PLZ
- Car Model: Mk5 gti
viewtopic.php?f=11&t=217296
Previous :too many to list
Re: OPC HELP NEEDED URGENTLY PLZ
Possible leak or split on a boost hose coupling or crack on intercooler.
- ICE King
Agreed, need to do a boost leak test and take it from there.
Ok will do a boost test ...anything else we should check ?
Leaking exhaust. Manifold to turbo, or turbo to downpipe
Ok thanks for the help guys car belongs to my brother in law trying to give him a hand while I'm at the coast ...on holiday at the moment will check it up next week and give feedback... what if it's not the intercooler ,manifold or boost pipes ? Boost pipes look ok will need to pull out the intercooler and send for boost test
