Intercooler to MK1 caddy
- Zoltan2222
- Car Model: A3 8L 2.0L 20VT
Hi
Which intercooler should I get to fit nicely infront of my radiator in a caddy mk1.
I have fitted the golf gti radiator (850 or something mm) allready.
Sent from my PRA-LA1 using Tapatalk
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
A3 8L 2.0L 20VT (project)
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
- Zoltan2222
Re: Intercooler to MK1 caddy
To cool AGU engine btw
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
You should fit the radiator and measure the size and space available and work from there.
I can suggest this, but it might not fit well or as good as you would like it to fit, example>>
You will need to get one that will fit in between radiator and grille, 50mm or 63mm core. You can squeeze a 76mm core in, but then there is no space between radiator and intercooler.
Length wise, you will need one that is the same length as that radiator either with straight outlets for the 90 degree bend silicone hoses or have aluminum bends welded to intercooler. Some guys run full height same as radiator and some lower height ones, all a matter of preference and space availability.
Dual headlights must go in most instances as the intercooler and or its piping catches on the spotlights.
There is an intercooler off a iveco turbo daily that fits perfectly on a mk1 but for the life of me I can't rembwr the specific model.
- Zoltan2222
Thanks guys, I bought a ford focus St3 rad today, it seems it will fit perfect, will let you know once i did the fitting
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
Rad or IC?Zoltan2222 wrote: ↑Tue Nov 13, 2018 6:43 pm Thanks guys, I bought a ford focus St3 rad today, it seems it will fit perfect, will let you know once i did the fitting
Yup. That's the one.
- Wheel Whore
I have used a 600*300 *76 cooler,removed 3 rows from the top so the bonnet catch closes properly.
mk4 gti R
- Zoltan2222
Sorry, its the IC from a ford focus, did not get to play last night but the IC pipes will fit part my rad and it seems thin enough to fit between rad and grill and also its low enough.
What impact does an intercooler have on a turbo, will a too big intercooler cause concerns?
For is it as simple as bigger is better when it comes to an IC?
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
No there is no advantage to going simply huge for no reason. If you are running a stock turbo on that engine you don't need a HUGE intercooler. It's a little bit of trial and error too and you have to be able to measure or look at temps.
