Hi guys.Please help with the above.Got a fried to do a diagnostic and the below codes seem to be issues;
P1114
P0139
P0033
P0243
P1531
P1093
P2414
P2146
P2149
P2008
P3138
P0100
Golf5gti 2005 epc light on and heavy knock
- chucker02
- Car Model: Citi ADY
Re: Golf5gti 2005 epc light on and heavy knock
Fark sakes
1971 VW beetle
1971 VW beetle
Need more info like what is the car doing and what is it not doing.
Giving a list of DTC's without any other information is the same as asking for directions and being told to go "there".
Hi.Sorry guys.Basically the car refused to start and when the above codes was cleared it started immediately.After a day the car was driven again and whilst going up an incline the Esp light came on and the vehicle switched off.After a few seconds when tried to start it,it started and the Epc light came on.The vehicle was driven for about a km further and on an incline it lost all power.
- Belix
- Car Model: Passat B8
Strange that all those errors would appear at once. A full scan log might reveal more that just the error code.
I've seen posts about multiple error codes being triggered by battery and main engine fuse issues.
I had a pile of error messages after a short drained my battery, but of course I could not start the car after.
- Wolf Mk2 16V
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
The heavy knock in your heading might be the clue. Other than that I'm not sitting and doing a web search for all those codes.
Post a proper scan with a proper cable and post then I'll look at it.
As far as fault finding goes, start with the basics like battery, fuses, oil and coolant, etc.
The fusable links on the battery break and can throw tonnes of errors, take a spanner and take each one out and put them back. Also look at the main fuses in the front of the fuse box next to the air filter housing.
Disconnect the battery before doing this.
- Voora Molester
and a moersa lot more.. im done now lolDt12 wrote: ↑Thu Sep 20, 2018 10:55 am Hi guys.Please help with the above.Got a fried to do a diagnostic and the below codes seem to be issues;
P1114 - o2 lamba
P0139 - 02 sensor
P0033- turbocharger Bypass Valve Control Circuit
P0033 - 004 - Malfunction / Open Circuit
P0243 - P0243 Turbocharger Wastegate Solenoid A Malfunction - OBD-Codes
P1531 - Camshaft Timing Adjustment: Open Circuit.
P1093 - Bank 1; Fuel Measuring System 2: Malfunction
P2414 - P2414 O2 Sensor Exhaust Sample Error Bank 1 Sensor 1
P2146
P2149
P2008
P3138
P0100
Thupercharged S4
