Help reading error codes 2013 Audi A4 1.8T
- Car Model: Golf MK5 2.0 TFSi
Hi Guys
hopefully someone here can help me.
my mum drives an Audi A4 1.8t
now the car starts, but the rev is high at idle and if you press the accelerator pedal it does nothing. when you press the break, the rev drops and becomes erratic.
the dash says esp malfunction and then start stop malfunction
i managed to scan the errors last night, but i dont understand what it says,
can i post it up here and someone here help me?
TIA
TIA
Re: Help reading error codes 2013 Audi A4 1.8T
Chassis Type: 8K (8R0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K2DA225069 Mileage: 118510km-73638miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CJEB) Labels: 06L-906-264-CJE.clb
Part No SW: 8K0 906 264 A HW: 8K0 906 264
Component: 1.8l R4 TFSI H07 0002
Revision: --H07---
Coding: 0A190012242501022000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM18TFS021K80906264A 001002
ROD: N/A
VCID: 2F6AC8FE76860C3940-807A
No ASAM data for: "EV_ECM18TFS021K80906264A" (AU48)
14 Faults Found:
15472 - ROD - Unknown Error Code
- 00 [101]
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2000.00.00
Time: 00:00:00
15462 - ROD - Unknown Error Code
- 00 [047]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 118514 km
Date: 2018.08.29
Time: 09:10:15
17789 - ROD - Unknown Error Code
- 00 [039]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Mileage: 118514 km
Date: 2018.08.29
Time: 09:10:14
15447 - ROD - Unknown Error Code
- 00 [035]
17178 - ROD - Unknown Error Code
- 00 [035]
15373 - ROD - Unknown Error Code
- 00 [175]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2018.08.29
Time: 09:10:14
15349 - ROD - Unknown Error Code
- 00 [032]
Intermittent - Not Confirmed - Tested Since Memory Clear
15341 - ROD - Unknown Error Code
- 00 [167]
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2018.08.29
Time: 00:03:52
15202 - ROD - Unknown Error Code
- 00 [109]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2018.08.29
Time: 09:10:14
14846 - ROD - Unknown Error Code
- 00 [175]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2018.08.29
Time: 00:00:28
14847 - ROD - Unknown Error Code
- 00 [047]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 118514 km
Date: 2000.00.00
Time: 00:00:00
14833 - ROD - Unknown Error Code
- 00 [039]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 118514 km
Date: 2000.00.00
Time: 00:00:00
15122 - ROD - Unknown Error Code
- 00 [038]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 118514 km
Date: 2000.00.00
Time: 00:00:00
15214 - ROD - Unknown Error Code
- 00 [032]
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CG HW: 8K0 907 379 CG
Component: ESP8 front H09 0100
Revision: -------- Serial number: --------------
Coding: 031544
Shop #: WSC 06325 000 00000
VCID: 00085B4293984341E9-8054
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 8
Reset counter: 94
Mileage: 118514 km
Time Indication: 0
Date: 2018.08.26
Time: 11:43:53
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x00A2
Hex Value: 0x0009
Hex Value: 0x6396
Hex Value: 0x0000
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 03B14000000000000000
VCID: 79FE36A6F0421289AE-802C
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0813000031616012
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 2313000040592008
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8K2 820 043 Q HW: 8K2 820 043 Q
Component: KLIMA 1 ZONE H02 0121
Revision: B0000000 Serial number: 01060320132793
Coding: 642402C000
VCID: 377AF09E86D6C4F918-8062
1 Fault Found:
03220 - Stop Valve for Coolant for Climatronic (N422)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 6
Reset counter: 8
Mileage: 105855 km
Time Indication: 0
Date: 2017.11.27
Time: 20:24:50
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DE HW: 8K0 907 063 DE
Component: BCM1 1.0 H16 0103
Revision: 05016001 Serial number: 00000044088202
Coding: 2600C0108034AFC00081400000001D0D0F1D030827090201000004000400020100000000000000
VCID: 75E63A96DC5A76E9CA-8020
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110313 H06 0080
Serial number: SWF13030110093
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21081973
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000603131416
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: AA494996000000000001
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H45 0610
Serial number: 003KFD98X57R
Coding: 30534435363030303030554A3052384B3053
Shop #: WSC 14091 002 1048576
ASAM Dataset: EV_AirabECUVWAUDI010 003010
ROD: N/A
VCID: 48988362F328BB0161-801C
Subsystem 1 - Serial number: 6334MSME787124518
Subsystem 2 - Serial number: 6344MSME7754280BI
Subsystem 3 - Serial number: 6352QSME152D1B6CS
Subsystem 4 - Serial number: 6362QSME0E2C1274K
Subsystem 5 - Serial number: 63732SME6C291640$
Subsystem 6 - Serial number: 63832SME6C290A444
No ASAM data for: "EV_AirabECUVWAUDI010" (AU48)
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 Q HW: 8R0 953 568 Q
Component: Lenks.Modul H02 0171
Revision: 00000000 Serial number: 20130313000627
Coding: 000016
VCID: 4FAAA87E1E466C3920-801A
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 931 P HW: 8K0 920 931 P
Component: KOMBIINSTR. H35 0556
Revision: 00400000 Serial number: UVL65VA3E
Coding: 3384080002010008010000
VCID: 3B72ECAEBAFEE099FC-806E
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0055
Revision: 1V070026 Serial number: 2641V1322884EB
Coding: 80CF07FF00
VCID: 48988362FB28BB0161-801C
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 7041660103
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13070000727011200181
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020202
VCID: 397EF6A6B0C2D289EE-806C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0304
Coding: 011C02204001410001
VCID: 56A45D1A219C1DF1E3-8002
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0011265249
Coding: 100000000001
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_RCEPSA4U8X 008014
ROD: N/A
VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_RCEPSA4U8X" (AU48)
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0302663865
Coding: 011A062200B900408130013680000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels: None
Part No SW: 8R1 035 223 A HW: 8R1 035 223
Component: DSP STD H08 0230
Revision: 26S00000
Coding: 0203010102
VCID: 2B52DCEE4A9E70196C-807E
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0304
VCID: 55A65A163C9A16E9EA-8000
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 00000001272692
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 3878F3A283C8CB8111-806C
3 Faults Found:
464128 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 94
Mileage: 118514 km
Date: 2018.08.26
Time: 11:43:53
Voltage terminal 30: 12.1 V
Internal Fault ID: 187
Vehicle speed: 0 km/h
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 134
Mileage: 118514 km
Date: 2018.08.29
Time: 09:05:58
Voltage terminal 30: 10.6 V
Internal Fault ID: 188
RWU: not active
DSD: not active
HTR: not active
ECD: not active
464640 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 134
Mileage: 118514 km
Date: 2018.08.26
Time: 11:43:53
Internal Fault ID: 189
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8R2 035 186 N HW: 8R2 035 186 N
Component: Concert3 H05 0470
Revision: 00000002 Serial number: AUZ5Z6M1867950
Coding: 0402008201018D000159071800
VCID: 418E9E46D8128A49A6-8014
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0304
Coding: 010C02204001210001
VCID: 59BE562650823289CE-800C
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H07 0304
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 F HW: 8T0 862 335 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005630210
Coding: 0010390
VCID: 3D76E2B664EAEEA9C2-8068
End-------------------------(Elapsed Time: 04:02)--------------------------
Revision: --H07---
ROD: N/A
14 Faults Found:
- 00 [101]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2000.00.00
Time: 00:00:00
- 00 [047]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 118514 km
Date: 2018.08.29
Time: 09:10:15
- 00 [039]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Mileage: 118514 km
Date: 2018.08.29
Time: 09:10:14
- 00 [035]
- 00 [035]
- 00 [175]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2018.08.29
Time: 09:10:14
- 00 [032]
- 00 [167]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2018.08.29
Time: 00:03:52
- 00 [109]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2018.08.29
Time: 09:10:14
- 00 [175]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 118514 km
Date: 2018.08.29
Time: 00:00:28
- 00 [047]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 118514 km
Date: 2000.00.00
Time: 00:00:00
- 00 [039]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 118514 km
Date: 2000.00.00
Time: 00:00:00
- 00 [038]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 118514 km
Date: 2000.00.00
Time: 00:00:00
- 00 [032]
Coding: 031544
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 94
Mileage: 118514 km
Time Indication: 0
Date: 2018.08.26
Time: 11:43:53
Freeze Frame:
Hex Value: 0x00C0
Hex Value: 0x00A2
Hex Value: 0x0009
Hex Value: 0x6396
Hex Value: 0x0000
Revision: 00002001
Coding: 642402C000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 8
Mileage: 105855 km
Time Indication: 0
Date: 2017.11.27
Time: 20:24:50
Coding: 00FD11
Coding: 02005D
ROD: N/A
Coding: 000016
Coding: 80CF07FF00
Revision: 00000000
Coding: 020202
ROD: N/A
Revision: 26S00000
Coding: 0203010102
3 Faults Found:
U1113 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 94
Mileage: 118514 km
Date: 2018.08.26
Time: 11:43:53
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 134
Mileage: 118514 km
Date: 2018.08.29
Time: 09:05:58
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 134
Mileage: 118514 km
Date: 2018.08.26
Time: 11:43:53
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Component: Display
Coding: 0010390
- Donavan
Audi A4 B8 2.0T - Daily
the problem is it says 14846 - ROD - Unknown Error Code .
i really dont know you to understand these things so i posted hoping someone will guide me.
is it going to be as simple as changing a few sensors or do i need a new ECU kind of thing
Need to update ur vcds bro
- cli 16v
- Car Make: Mazda
- Car Model: CX5
Based on the above you are using a generic (fake) VCDS cable. Get an original Ross Tech cable and scan the car. Did you by any chance unplug the electronic hand brake & ESP switch?
'15 MKVII GTi
'07 MKV GTi OEM+
'89 MKII Golf CSL OEM
'97 MKIII GTi Exec
'15 MKVII GTi
'07 MKV GTi OEM+
'97 MKIII GTi Exec
- Membership No: 3103
As mentioned above, the error codes dont correspond to Ross Tech Library. I suggest that you give your location and one of the members can help you with a propers VCDS scan.turbowheelchair wrote: ↑Fri Aug 31, 2018 5:08 pmno can do, its not my VCDS. borrowed my neighbors pc and cable.
i cant drive the car, so my options are limited
http://wiki.ross-tech.com/wiki/index.ph ... 3#mw-pages
'09 8P S3 Sportback (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
im in Reservoir Hills in Durban.
ill greatly appreciate someone helping me with scanning the car.
