2008 G5 Gti 1st Gear issue
Please help,..my car not taking 1st gear. All other gears sharp but first gear, even with car off no first gear.
Please help,..
08 G5 GTI__1st Gear Issue
- Car Model: White-G5 GTi
Re: 08 G5 GTI__1st Gear Issue
Selector or gear failed. Get the box repaired. Or find another one.
Thanx Panic, will check it this weekend. Took box of and found clutch gona, yet still when box of cannot select 1st gear. so not sure tho
if you can't select 1st at the gearbox itslef then the fault is inside - so either a selector or a shift dog or something. Open it up is pretty much the only choice.
Thanc buddy,...I am gonna work on this tomorro! Fitting everything new from Fly to clutch etc.
Will keep u updated
Will keep u updated
Box came right on its own,..noty sure why but ya.
Have not had issues since July and going strong.
NB: I filled box up with 1lte oil and was still niot leaking.
Should I throw more oil?
- Car Make: SEAT
- Membership No: 478
If you drained it completely then you need to fill the box with 2.3 litres. If you aren't sure, fill the box until the oil starts to drip out of the filler hole.
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
