20V Turbo Build Advice
- Membership No: 1919
Hi Guys
Car Polo Cassic (6N) 1.8 8V 2002 Model
Please can you supply abit of advice.
I am going to be using my 1.8 8v block from my Polo classic, I am going to to be changing the pistons and rods to accommodate the 20V head. I also know that there is 3 ports I need to block of on the head to make it work with the block.
I am getting the head and the turbo (K03).
What I need to know is where do I tap for a oil feed for the Turbo as well as if I want to do 180/190kw on wheels what do I need get as in rods and pistons.
Also what other parts and stuff do I need? (below list of stuff I know I need to get or already have)
20VT Head
K03 Turbo
Pistons (what make?)
Rods (what make?)
Gasket Set
FM Intercooler
Boost Pipes
Downpipe
DV
Please tel me if I missing anything from the list
Kind Regards
Brat Boy
20VT Head
K03 Turbo
Rods (what make?)
Gasket Set
FM Intercooler
Boost Pipes
Downpipe
DV
Kind Regards
Brat Boy
Polo (9N3) GTI
Polo (9N3) GTI
Re: 20V Turbo Build Advice
uhm 180/190 WHEEL kw with a K03. good luck with that.
Stock rods is fine. Get pistons from an S3 of those years.
- Boost
- Car Model: Caddy pickup
- Membership No: 1921
Yeah. That power out of a K03 is a tall order.
Oil feed can be taken form the oil filter housing. You need to accommodate a large oil drain as well on the Sump.
You will also need water supply. The 06A blocks have this but you will need to make another plan.
You will also need to look at fueling. Stock pump might be an issue
A management system. Get something that can control the N75 valve or get a stand-alone boost controller.
Current: 2008 VW Caddy R-Line 20V BIG T
2009 CW 9n3 Polo Gti
2012 Holden Captiva 2.2d LX
2011 Holden Cruze Equipe
2010 Great Wall V240 Ute
2017 Chev Captiva 2.2d LT daily
2000 Vw Citi 1.6i
2013 GW Audi A3 Sportback 1.8TFSI SE S-Tronic (POS)
2006 Volvo S40 T5
2004 Nissan 350Z Coupe
2000 VW Golf 4 GTI (247wKw @ 1.3bar)
2007 Fiat Grande Punto
1994 Fiat Uno Turbo
1994 Fiat Uno Pacer
2000 Vw Citi 1.6i
2006 Volvo S40 T5
1994 Fiat Uno Turbo
1994 Fiat Uno Pacer
management will be Dictator 60-2
Polo (9N3) GTI
Polo (9N3) GTI
Water supply you can get from a heater supply cut one of them and divert it through the turbo.
Quite frankly unless you got the stuff for free it's actually cheaper to just buy a complete 20vt motor than to build one yourself.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
That sort of power on a k03 wont happen on 95.
At altitude a k03s will max out around 150wkw, thats with the oem management and WMI. The same setup on Dictator would probably get 130wkw.
The S3 pistons that panic mentioned have a 20mm wristpin so 8v rods will work fine for your power goals. I would possibly look at a decent spec k03 hybrid or t28 for your power goal.
- Tman21
- Car Model: BosPolo
- Membership No: 3247
Get a GT28 if you looking for 190wkw
#TMAN21
#TMAN21
Hi Panicpanic-mechanic wrote: ↑Fri Jun 15, 2018 8:54 am Water supply you can get from a heater supply cut one of them and divert it through the turbo.
The pistons I will get for free as well as the turbo, the only thing that I am going to pay for is the head. Thanks for the info on the water supply will keep that in mind. I priced the 20v Turbo motor they selling for R14900. The head is costing me R3500. If I get the complete motor I will have also get the car re registered, I am not up for that.
So in a financial sense this option works out cheaper plus I will be doing all the labour except for the wiring aspect of the management.
Again Panic thanks for the advice
Polo (9N3) GTI
Polo (9N3) GTI
Price of said turbo please?
Polo (9N3) GTI
Polo (9N3) GTI
That is also a option of a proper specced K03 hybrid, the turbo I will get for free I just need to do the mods to itKillerwatt wrote: ↑Fri Jun 15, 2018 9:02 am That sort of power on a k03 wont happen on 95.
Polo (9N3) GTI
Polo (9N3) GTI
- Tman21
You looking at around 4500zar for a "good" chinese turbo which will work perfectly if you dont boost more than 1.0bar every day all day.
Try Mr Turbo for quotes.
#TMAN21
#TMAN21
You don't re-register a car for another engine. you just change the detail on the registration form but yes it is somewhat of a schlep.
Datadot, police clearance, registration department.
@Panic
As the build goes along I am sure you will give me more advice on best methods so I look forward to it.
The data dot and police clearance is the annoying part
Polo (9N3) GTI
Polo (9N3) GTI
- ob wan
- Car Model: MK1 2.0 16vT
ola, the pm system doesn't work too lekker, but it's R2500 for a turbo mani
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
97 LSvtec (ex)
Thank you sir
Polo (9N3) GTI
Polo (9N3) GTI
