2004 Golf 4 GTI (AGU)- Missing on full throttle
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn »
Hi guys,
So a friend of mine at the workplace has a Golf 4 GTI that is currently doing a tad over 300,000km's. The engine has never been opened before, and I must say that for its age the car goes really well.
So onto the problem:
When idling: The car has a clear miss below 3000rpm, over that and it sounds clean.
When driving: The car has an even bigger miss once load is applied, the miss is more apparent at WOT than POT. However, what is very strange is that the problem is there most of the time but clears out every now and then- in this case the car goes perfectly fine like it should. In 2nd gear @ POT, the car would surge from idle to about 3500rpm and if kept at POT- @ 4000rpm the miss would clear out and the car would go perfectly.
Things that have been changed: O2 sensor, N75 valve
What are the other possible things that could be looked at?
Good help is always appreciated.
farrell15
Car Make: Hyuandai
Car Model: Tiburon FL2 GTv6
Re: 2004 Golf 4 GTI (AGU)- Missing on full throttle
Post by farrell15 »
8VALVE-zn wrote:Hi guys,
Does he or yourself have access to VCDS?
Sounds like maybe plugs could be gapped wrong or even a failing coil pack but I can't say for sure. If you have access to a scanner scan it for errors it's usually a good to start.
Sent from my SM-N900 using Tapatalk
2009 Hyundai Tiburon FL2 GTv6 (Big turbo project)
2009 Golf MK5 GTI dsg (SOLD)
1979 Golf MK1 2L (SOLD)
2007 Polo 1.9 TDI (BEEEEEEG turbo) (SOLD)
1998 Jetta MK3 ABF 2.0 16v (SOLD)
1990 Jetta MK2 ABF
1968 Baja bug 2.0 Kombi project ABF (SOLD)
Precision Auto Works
2003 Audi 1.8t 20v GT28
2002 Polo 9n 1.9 tdi PD100
farrell15
Car Make: Hyuandai
Post by farrell15 »
1990 Jetta MK2 ABF
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn »
Testing of the coilpacks will happen today.
The missing story is very very irritating because it could be anything really
Thanks for that!
dcmk4
Registered for: 9 years 11 months
Car Model: MK7 GTi
Post by dcmk4 »
AGU coilpacks are pretty robust and don't often fail like the other 20v turbo engines coils.
Any idea if there is software on the car?
'14 Golf Mk7 GTI
THANAS STG/// ECU&DSG
Littco L380x
All the ponies
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn »
The car is completely stock.
What's baffling is that the problem is only there every now and then.
The coilpacks have still not being tested, the coilpacks have been changed over the life of the vehicle (remember its on 300k km +).
There is a bit of a fuel smell coming into the car ever since the problem started.
Today it seems like the issue of missing is there even at POT, strangely tho if kept at POT and the engine is allowed to revv up past 4000rpm the issue some what clears up.
What else can be checked at this point?
dcmk4
Car Model: MK7 GTi
Post by dcmk4 »
Fuel or vacuum leak perhaps, check the injectors cups which are screwed into the intake manifold and see if they are leaking as you will easily spot if there's a leak. The injectors basically get seated in them.
Those parts fail over time I've had to replace mine as well.
'14 Golf Mk7 GTI
Littco L380x
All the ponies
Check the air/fuel ration on a dyno. If the thing goes lean under boost it will missfire as well. had quite few of them recently - the pumps are now at that age that they are starting to fail. The fact that it does it on WOT mostly can definitly point to a lean situation.
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn »
what are the apparent problems experienced with a bad N75 valve? And what are the symptoms of a bad N75?
dcmk4
Car Model: MK7 GTi
Post by dcmk4 »
A failed n75 would generally result in overboosting as it doesn't handle the boost pressure appropriately or it could result in no boost if it's somehow stuck open.
'14 Golf Mk7 GTI
Littco L380x
All the ponies
n75 stuck open will cause overboost. Stuck closed or have died will cause underboost or basically just wategate pressure which is 0.3 bar.
Closed is it's default valve - held there with a spring. activating the circuit opens the valve
dcmk4
Car Model: MK7 GTi
Post by dcmk4 »
Oh right, mixed those up.. :twisted:
'14 Golf Mk7 GTI
Littco L380x
All the ponies
22irwin.mercure
Registered for: 7 years 6 months
Car Model: S3
Post by 22irwin.mercure »
Check if your fuel pump was replaced bud .
Sent from my m1 note using Tapatalk
madhoshival
Registered for: 8 years 6 months
Car Model: 9N3 GTi
Post by madhoshival »
Is the misfire only there on boost? Did you check for boost leaks? Also check your map sensor.
