white smoke
white smoke
[*]hi everyone i am getting a cloud of white smoke when pulling away in 1st after sitting in traffic for a while what could be the problem
- RedBeard
- Car Model: Mk1 2-door Golf
Re: white smoke
Could be overfeuling
Daily : 2011 Toyota Aygo 1.0 (Tiny)
Soon-To-Be-Project : 1981 VW Golf 2-door (Unikorn)
Link for slow build - viewtopic.php?f=11&t=208217
Ex : 2005 Hayundai Getz 1.3(Chuckie)
- dcmk4
- Registered for: 10 years
- Car Model: MK7 GTi
Re: white smoke
What car is it/what engine?
Re: white smoke
Petrol cars
- white smoke is generally coolant being burnt
- if mistaken for grey oil smoke then it could be worn valve stem seals or guides
Diesel cars
- normally unburnt fuel from leaky injectors
Diesel cars
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
Re: white smoke
How many kilos on the car? Could quite possibly be the turbo seals are on the way out, causing small amounts of oil to leak into the zorst and that is causing the smoke.
Or it could be valve stem seals.
- dcmk4
Re: white smoke
Sounds like the typical valve stem seals the 20v engines face.
If you slow down in gear and accelerate again after a bit, can you see any smoke? That's an easy indicator after pulling vacuum while slowing down.
