2006 BWA misfiring
- Car Model: Mk5 GTI
2006 BWA misfiring
I've got a golf 5 gti dsg 2006 bwa spec , the car has a serious misfire which tends to occur under hard acceleration or after 3000rpm or so .. I have fitted new R8 coilpacks, sparkplugs and replaced the pcv valve, and yet the car is still misfiring . I drove the car this evening after fitting the new coilpacks and plugs and it never misfired at all on the test run, just when I thought the problem was solved it started misfiring again.. Im seriously unsure of what is causing the misfire .. any help or thoughts will be much appreciated, thanks
Kind Regards
Riley
Kind Regards
Riley
- Gollum
- Car Make: Renault
- Car Model: Megane RS
Re: 2006 BWA misfiring
Leaking/faulty injector?
Had the same issue on an a3. One of the injectors was the issue.
- Uncle Nunda
- Post Whore
- Car Model: S3
- Membership No: 1489
also check your cam follower and High pressure fuel pump
Thanks for the reply Gollum , I was told it could be a leaky injector so I bought new seals for all the injectors and fitted them in last week even though the old seals were still great
Thanks for the reply bud , I still need to run a vcds on it hoping that'll let me know what it is so I don't spend unnecessarily. You could very well be right as I've been reading on the forum those parts can be at faultUncle Nunda wrote: ↑Tue Jun 05, 2018 7:48 am also check your cam follower and High pressure fuel pump
Check for any bad connections in plugs and wiring to coilpacks and injectors.
- dazza
- Car Make: VW and VW
- Membership No: 1327
Could also be low pressure fuel pump that is poked
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
Let it idle for a while when missing symptoms occur. Remove the plugs and check which one is soaked in petrol. probably that injector is the faulty one. Multiple missfire detection could also mean dodgy injector.
I had misfire a while back..turned out that the Bank 1 O2 sensor (top of the downpipe where it meets the turbo) was kaput. Changed it out and all good.
Thanks so much guys for the replys , I drove it this morning and its not missing at the moment will drive again now and post on the feedback.. definitely have to plug a diagnostic to it soon for the now and then irregular idle
Just drove it now and all seems to be good ,thinking it could've been dirt in the injector/injectors so something . Its running well now just a bit shakey on idle now and then will check cam sensor .. big thanks to all you guys
Kind regards
Riley
Kind regards
Riley
So problem seem to have vanished. Do a scan and check if you have any faults showing. Shakey idle tells me something is still not right.RileyG5gti wrote: ↑Tue Jun 05, 2018 6:42 pm Just drove it now and all seems to be good ,thinking it could've been dirt in the injector/injectors so something . Its running well now just a bit shakey on idle now and then will check cam sensor .. big thanks to all you guys
Kind regards
Riley
A few days ago the problem occured again and is present ,the mis is currently the worst it has ever been where the car actually struggles to idle and wants to stall, although when I got back home and idled it in my garage it the mis improved . I also switched the car off and started it again and still had the bettered mis whilst holding it on 2000rpm, since then the car has been parked off and last night I unplugged the battary as I've been told it resets the computer box . I have also found that my fuel pressure regulator/sensor on the hpfp is cracked vertically which sounds pretty common as a result of previous owner or vw dealer negligence by pushing the engine cover on hard it breaks as its really close up, really hoping that's the issue . Goldwagen also doesn't sell the part separate have to purchase the whole hpfp which is rather costly.PapaJo wrote: ↑Sun Jun 10, 2018 9:41 amSo problem seem to have vanished. Do a scan and check if you have any faults showing. Shakey idle tells me something is still not right.RileyG5gti wrote: ↑Tue Jun 05, 2018 6:42 pm Just drove it now and all seems to be good ,thinking it could've been dirt in the injector/injectors so something . Its running well now just a bit shakey on idle now and then will check cam sensor .. big thanks to all you guys
Kind regards
Riley
If It doesn't solve the issue it'll have to go to a guy who can fault find the problem , please let me know who I could take it to for further assistance . But first let me get a new fuel pressure regulator. Thanks man
disconnecting the battery just cuases a whole lot of false faults in the management and that is about all it achieves.
I've installed a brand new fuel pump this evening from goldwagen and the list of faults on the vcds has decreased from 8 faults the other day to 5 today , however im Still getting a low fuel pressure fault, it says the fuel sensor is intermittent and another issue I noticed when I drove it,is the car refuses to boost anymore its feels very underpowered.. think im in for a new diverter valve ?
Pay attention to the low fuel pressure fault first. Once that is resolve other errors will clear too. Possible bad fuel sensor.
Going to install a new diverter and fuel sensor this evening ,im hoping that solves the issue of the "Too low fuel pressure" fault and the loss of power .. Thanks for the help will post an update soon . Hoping this solves the problems
- Committee Member
- Car Model: Audi S3 Sedan
- Membership No: 1215
What is the actual faults you are getting on vcds, Please post the fault codes here, It seems that you are just replacing things based on not much info
Just replacing random parts isnt going to solve the issue
Grant Hendry
Membership no.:1215
2016 Audi S3 Sedan
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
Membership no.:1215
2016 Audi S3 Sedan
2007 VW Golf GTI
2012 VW Polo GTI
Ok will post the faults sir ... put the new fuel sensor and dv on but still got a bit of a shakey idle
The low fuel pressure will possibly cuase every single other issue you get. Resolve that first as that will cost you a motor in the long run. Only then worry about the rest. The system will cut boost if there is not enough fuel pressure or if it thinks there isn't IE it will actually close the throttle or open the DV to save the engine. IE cut boost.
Thanks Stephan for the help, btw got the boost back by replacing the DV with a newer design piston type the original DV,s rubber diaphragm was cracked , I understand what you mean as one faulty part could link to a few faults , do you perhaps know an affordable trustworthy mechanic that's clued up with these golf 5 gti,s that could find the problem? Just about had enough of changing unnecessary parts which i think could be the problem that cost big bucks lol, I will still post the faults from the vcds of my pc . Thanks againpanic-mechanic wrote: ↑Fri Jun 15, 2018 6:48 am The low fuel pressure will possibly cuase every single other issue you get. Resolve that first as that will cost you a motor in the long run. Only then worry about the rest. The system will cut boost if there is not enough fuel pressure or if it thinks there isn't IE it will actually close the throttle or open the DV to save the engine. IE cut boost.
Cheers
You supply not a single even hint of a location so impossible to refer you to somebody.
I stay in the Pretoria centurion area, got the misfiring issue sorted it was a faulty injector ,but now sometimes under hard acceleration the car experiences a sort of flat spot where the car seems to electronically cut the fuel or there's actually a shortage of fuel? , the accelerator is open at full throttle but the car refuses to rev more that 4000rpm the vcds shows one fault (P0087 - Fuel Rail/System Pressure Too Low - Intermittent) that is the only fault present nothing else, I've ordered a new cam follower from Goldwagen but it hasn't arrived yet, is there by any chance a worn cam follower( even though it looks fine) cause this issue ? Thanks once again.panic-mechanic wrote: ↑Fri Jun 15, 2018 7:51 am You supply not a single even hint of a location so impossible to refer you to somebody.
