Hi All,
I recently purchased a Golf 5 GTI DSG to be used as a daily drive to work and back.
It has been really good to me thus far but i am having an intermittent issue.
Car idles and drives perfectly but once every few weeks the car cuts power and wont rev passed 2k rpm (Normally happens after i have been driving for a while and not cold). If you accelerate it just does nothing.
Car does not cut out and still idles fine. I have to basically pull off switch the car off for a few minutes and its perfect again.
I bought a VCDS cable and software an i am getting the following error:
012555 - Low Pressure Fuel regulation
P310B Fuel Pressure Outside Specification - Intermittent.
also getting Fuel Rail/System Pressure too low P0087 which im sure is being triggered due to the above error.
After doing some research its recommended to change the trust sensor, if issue still persistent i need to change the in tank LPFP.
I called goldwagen and its around 1200 for the sensor and same price for the in tank LPFP. Are there any aftermarket sensors available cheaper before i go the ebay route?
Thanks Guys.
Golf 5 GTI LPFP issues
2010 e92 335i Rennzport Tuned
2007 Golf 5 GTI DSG
EX Rides: 1991 e30 318i Vert, 1996 Jetta VR6 EXEC, 2002 Mini Cooper S, 2005 e46 320i Individual, 2007 E90 325i Msport, 1990 E30 318i, 1996 Golf 1, 2005 E82 130i Msport, 2011 E90 LCi 330d Msport, 1998 e36 323i motorsport, 2004 E46 M3 Vert, 2010 Audi A4 2.0T, 1998 E36 323i Motorsport
2007 Golf 5 GTI DSG
Re: Golf 5 GTI LPFP issues
that sensor rarely fails. rather change the pump first
I decided to change the cam follower today and i noticed the o ring on the hpfp was damaged and the previous owner used silicone to seal it. Also the fuel feed pipes where leaking due to it not being tightened.
Bought a new o ring cleaned it up and it feels better. Will just monitor. I already orded the sensor on ebay. Will just stash it.
2007 Golf 5 GTI DSG
2007 Golf 5 GTI DSG
