Hesitation in gear changes
- Registered for: 6 years
Good day all. Have a 2015 Golf 7 GTI. I installed stage 1 software on it. Since this now, there is a slight problem on the car. When I accelerate, not very hard, there seems to be a slight jerk when it changes from 3rd to 4th. Any idea what it could be? Its mostly just from 3rd to 4th and like I say it's as if there is a slight hesitation and then the power is back.
- Car Model: S3, Polo Playa,
Re: Hesitation in gear changes
You have can do dsg software to illuminate the problem, gearbox ecu calculate torque that might be a bit to much for oem software on dsg box.
- BdtDSG
Had the same issue happen to me once, loaded a different file and hesitation went away.Heikz7GTI wrote:Good day all. Have a 2015 Golf 7 GTI. I installed stage 1 software on it. Since this now, there is a slight problem on the car. When I accelerate, not very hard, there seems to be a slight jerk when it changes from 3rd to 4th. Any idea what it could be? Its mostly just from 3rd to 4th and like I say it's as if there is a slight hesitation and then the power is back.
Will flash dsg box and see what happens. Just going to take software off as well. Maybe it is bigger problem.
- BdtDSG
Mine was on a MK5 Gti DSG, loaded the file and I felt hesitation straight after the flash. Put the stock file back a week later and the hesitation was gone. Try stock file first before spending extra money. They usually copy your stock file before they map the car, so should be quick and easy.Heikz7GTI wrote:Will flash dsg box and see what happens. Just going to take software off as well. Maybe it is bigger problem.
