2.0T Stripped TB Threads on Intake Manifold
liv
Post by liv » Wed Feb 21, 2018 4:23 pm
Hi guys... tried replacing the throttle body on the DTM, and upon removing the old TB, it looks like the threads in the plastic intake manifold are poked so I cant get the new TB on properly. Any ideas on how I can get the TB refitted? Intake has since been removed.
2018 VW Golf GTI DSG
2016 Audi A3 TFSi Sedan S-Tronic
Life160
Re: 2.0T Stripped TB Threads on Intake Manifold
Post by Life160 » Wed Feb 21, 2018 4:24 pm
Helicoil could work?
MK6 GTI 12' (APR)
Citi Life 01' - 1.6i 8v :(
76.6kw/144nm (RBTS)
liv
Post by liv » Wed Feb 21, 2018 4:32 pm
Life160 wrote:Helicoil could work?
have no idea, even if i could find it... lol. Is there anywhere I could go to get helicoil installed?
Life160
Post by Life160 » Wed Feb 21, 2018 4:34 pm
Do a quick google search - it’s pretty specialized so needs a helicoil trained guy. There should be a call out fee and then a charge per hole they need to thread.
MK6 GTI 12' (APR)
76.6kw/144nm (RBTS)
Car Make: VW, VW, Aprilia
Car Model: Mk2, Mk3, Aprilia RSV4
Post by Jetta2 » Wed Feb 21, 2018 4:49 pm
Life160 wrote:it’s pretty specialized so needs a helicoil trained guy.
Not really, no.
If you can use a drilling machine properly and drill a hole straight, then it is simple.
1989 Mk2 Jetta 2.0 8V-T
2017 Caddy Maxi Crew Bus
2013 Aprilia RSV4 APRC
Post by panic-mechanic » Thu Feb 22, 2018 1:20 pm
What was wrong with the throttle body ? They don't easily die.
It was the idiots in pietermaritzburg that stripped those. You can't helicoil or insert becuase of the self tapper type thread on the screw. So you put them in with pratley plastic steel epoxy. Give it till the next day to dry and then tighten it a bit more.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
FrancoisMK2
Car Make: Kia, VW
Car Model: Sportage, Golf 2 1.3 cl
Post by FrancoisMK2 » Thu Feb 22, 2018 3:05 pm
Won't drilling and taping in new thread work ?
The TB on my kia had the same problem where the aluminum stripped, however on the kia it is possible to drill a hole straight through and put in a longer bolt with a nut on the back.
Not sure if it can be done on the VW motor though, you will need to check first.
As I lay rubber down the street.
I pray for traction I can keep, but if I spin
and begin to slide, please dear God protect my ride.
liv
Post by liv » Fri Feb 23, 2018 2:02 pm
panic-mechanic wrote:What was wrong with the throttle body ? They don't easily die.
I figured it was the previous guys that stuffed up the threads.
Car kept throwing a CEL, with a fault on the TB which was happening intermittently - assume its the TB actuator as that usually fails on these TB's, and you can see the wear on the gear where it typically idles. Got a working TB so figured i'd swap it out.
Will try your method... is definitely my preference compared to drilling out the manifold. much easier to try this fix with the manifold off the car, but refitting the intake with the TB installed is a mission...
liv
Post by liv » Fri Feb 23, 2018 2:04 pm
FrancoisMK2 wrote:Won't drilling and taping in new thread work ?
Unfortunately these are plastic manifolds... spoke to a thread specialist, and he says he has fitted helicoil to these manifolds before, but you wont be able to use the OEM bolts as Panic mentioned. Will try the pratley option and go for the helicoil with aftermarket bolts option if that fails.
