2.0 8v turbo
Trevor2205
2.0 8v turbo
Post by Trevor2205 » Mon Feb 19, 2018 7:21 pm
Howsit howsit people,, so im planning on turbocharging my mk1 golf with 2.0 8v ADY long block motor in,,so i want to know the following:
The correct size turbo for the motor
Which pistons can i use for the motor
What can i boost max with the pistons in previous question
And what power figures could i expect with the setup?
Info would be much appreciated.
Stu
Re: 2.0 8v turbo
Post by Stu » Tue Feb 20, 2018 7:02 am
easier to get a 16v turbo motor and use that or the 16v head at least - there are a few guys running the 16v turbo motors and they make great power
Polo 20VBigT - The Redhead
C63 507 Edition - The Dragon
Re: 2.0 8v turbo
Post by panic-mechanic » Tue Feb 20, 2018 10:36 am
Turbo size depends on what you goals are.
Use the stock pistons, add a 16v head - sorted
The pistons is not what stops you from boosting. It is the fuel octane that you have access to vs compession ratio. Using the stock 8v piston with a 16v head puts you at around 8.5:1 which you can boost to around 1.2 bar without pulling too much timing.
Power figures will depend on the turbo and how good your tuner is.
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
dstyler
Car Model: POLO 9N
Re: 2.0 8v turbo
Post by dstyler » Tue Feb 20, 2018 10:59 am
Good Morning Guys i know this aint related to the above topic
i have a vw polo 9n bah how do i test the cam shaft sensor anmd what the car is doing while driving as soon as it comes to a stop or put your clutch in it cutsoff doesnt have a problem starting up again , I did start the vehicle and disconnected the lug going to the cam sensor hence nothing happened extremely puzzled now
Re: 2.0 8v turbo
Post by panic-mechanic » Tue Feb 20, 2018 11:07 am
If you go to the relevant sub section like naturally asprirated or general tech questions you can post you own thread instead of jumping into somebody elses's totally unrelated thread.
You need vcds and in mearing values or advanced measuring values look for the block that contians the camshaft rpm. Of it shows nothing it ain't working. Even if it is dead the car will resort to simply fuelling in batch mode and it might be a tiny bit heavier on fuel overall. But it won't stop the engine from running.
'07 Audi A4 2l TDI
dstyler
Car Model: POLO 9N
Re: 2.0 8v turbo
Post by dstyler » Tue Feb 20, 2018 11:53 am
Thank you
