S3 8L clunking noises - Subframe Bolts ?
P1LAYA-ZN
Car Make: Audi, VW and Toyota
Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Post by P1LAYA-ZN » Fri Feb 16, 2018 12:39 pm
Good Day gents,
For a long time I've been experiencing clunking noises on my front suspension when turning, parking, taking off or hard on the brakes, so was wondering if this would be as a result of my subframe being changed and possibly bolts needing replacement.
I think there are only 4 bolts.
Are they agents only part ?
Could it be any other common part that needs replacement, other than subframe bolts?
Are there any upgrades to these suspension parts that are readily available ?
Thanks.
#Builtnotbought
Donavan
Re: S3 8L clunking noises - Subframe Bolts ?
Post by Donavan » Fri Feb 16, 2018 1:13 pm
Had the same issue
In the end, after replacing almost everything I tracked down to very badly worn ball joints and tie rods that were the wrong way around :lol:
Audi A3 1.8t 20V
http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=33370
LostEnigma
Car Model: S3 8L
Membership No: 3207
Post by LostEnigma » Fri Feb 16, 2018 11:29 pm
Dog bone engine mount.
Control arm bushes.
Top shock mounts.
All known weakpoints
2003 Mexico Blue Audi S3 8L 280.7 WKW - 424NM - Bagged by FS Projects, YT Revision & Only Charged Dubs - ISPIRI WHEELS FTW
2013 VW Candy White Polo Vivo GT - SOLD
1997 VW White Chico Golf - SOLD
P1LAYA-ZN
Post by P1LAYA-ZN » Mon Feb 19, 2018 10:26 am
LostEnigma wrote:Dog bone engine mount.
Control arm bushes.
Top shock mounts.
Are there any upgrades to these bushes or do i just get them replaced with the stock 1s ?
Shock mounts I replaced when fitting my coilies.
I never did check that Dogbone mount, where can I get an upgrade ?
Thanks :wink:
#Builtnotbought
LostEnigma
Car Model: S3 8L
Membership No: 3207
Post by LostEnigma » Mon Feb 19, 2018 10:53 am
Control arm bushes.
Top shock mounts.
Thanks :wink:
Dogbone mount - Get the PowerFlex version - Not sure who stocks these currently.
Control arm bushes on the s3 are unfortunately the ones from the A3.. The TT ones are the strengthened ones, you can get them from agents. Not expensive
