Also an option although just fitting 1 x Mk1 fuel filter is cheaper and easier.MK1-GT wrote: ↑Tue Sep 18, 2018 10:08 am found this also ..
This guy deleted the canister using 2 mini K&N filters, no problems for the last 6k miles and of course no CEL.
https://www.golfmk6.com/forums/showthre ... 546&page=3
MK6 EVAP system issues
- Le Clue
- Membership No: 1458
Re: MK6 EVAP system issues
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- Car Model: Golf IV GTi (132KW)
- Membership No: 1158
Hi Guys,
Just an update, So yesterday I got MK1 fuel filter and 1M Piping and fitted it.. So Charcoal canister is being bypassed.
I drove 150km since yesterday and Engine light has not yet come back on..
I also noticed that the car is much lighter on fuel...
Can blocked or damaged Charcoal canister cause car to be heavy on Fuel?
Kuven Aramugam
E-Mail: kuven0107@gmail.com
Contact #: 083 716 4455
2005 VW Polo 1.9 TDi Sportline
2010 VW Golf MK6 GTi DSG
Previous Rides:
1984 MK1 GT (Sold)
2003 Golf 4 1.6i 2door (Sold)
1967 VW Split Window Panel Van(Sold)
1962 VW Split Window Crew Cab (Sold)
2003 Golf 4 GTI(sold)
Previous Rides:
1984 MK1 GT (Sold)
- Car Model: MK6 GTi
Nice, any pics and what size piping did you buy and what did you end up using ?MK1-GT wrote: ↑Tue Sep 25, 2018 8:49 am Hi Guys,
I will take a pic or 2 later. But might need to make it neater or hide it..
Not sure size of piping.. Asked guy as spares shop for 1 Meter pipe to fit MK1 Fuel filter.
Only used about 1/2 meter or less..
Used same pipe from the N80 that was going to Charcoal filter, now going to fuel filter and then new pipe from fuel filter to tank return..
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
That will be a great help, much appreciated.
Ok I spoke to soon.. Went out lunch time to the shops and Check Engine Light came on again...
Will check this evening if it giving same error..
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
Below is a picture of how I put the Fuel filter... I left the Charcoal canister in its place....
Kuven Aramugam
Previous Rides:
1984 MK1 GT (Sold)
Previous Rides:
1984 MK1 GT (Sold)
Much appreciated, this is exactly what I needed to see !!
- Belix
- Car Model: Passat B8
The light can be caused by other errors too, such as a fuel cap that does not seal, or a faulty N80 valve
How will you know what it is if the fault scan just says evap problem?
- Belix
From what I've read, it's a bit of trial and error sadly. You can run a test on the valve using VCDS - https://www.audizine.com/forum/showthre ... ng-VAG-COM
